10-24-2016, 19:19 | #1 (permalink) |
Freak Poster Join Date: Sep 2012
Member: 1808452 Status: Offline Thanks Meter: 21 | Infinix X510 Clone SC7731c Android 5.1.1 can't be read Chinese Miracle II [SPD module] v 1.22 Operation : Check/Read Info [ v1.22 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
10-25-2016, 08:52 | #5 (permalink) |
Member: 1808452 Status: Offline Thanks Meter: 21 | Yes, did all that. Selected and deselected Alternative LDR Mode and chosed sc7731(Generic), Android 5.x and Crev/Android 6.x making in total 6 operations but no success. Even tried other CPU boot type as well but no success. I wish you had one of that phone on your desk for study Last edited by busfield; 10-25-2016 at 08:58. |
10-30-2016, 09:11 | #8 (permalink) | |
Freak Poster Join Date: Jun 2014 Location: ALL THINGS ARE POSIBLE WTH ***
Member: 2203712 Status: Offline Sonork: 100.1667064 Thanks Meter: 82 | Quote:
Code: Start at : [10/7/2016 / 9:36:54 AM] Operation : Check/Read Info [ v1.22 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : X510 Model Brand : Infinix Model Device: X510 AndrVersion : 5.1 BaseBand CPU: SP7731CEB CompileDate : 4/26/2016 1:23:35 AM Project Ver : VERSION_V05_20160425 Model Ext : X510 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:26 Reconnect Power/Cable! Finish at : [10/7/2016 / 9:37:22 AM] Code: Start at : [10/7/2016 / 9:54:22 AM] Operation : Read FullFlash [ v1.22 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Prepare Ok! - > Wait phone connected ... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! - > Wait phone connected ... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : X510 Model Brand : Infinix Model Device: X510 AndrVersion : 5.1 BaseBand CPU: SP7731CEB Project Ver : VERSION_V05_20160425 Model Ext : X510 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_Trunk_W15.49.3_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : oem.bin [Read Ok] : sysinfo.bin [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 1942 MiB Saved to : C:\InfinityBox\CM2SPD\Flash\SP7731CEB_X510_5.1_VERSION_V05_20160425_X510\ Done! Elapsed: 00:16:01 Reconnect Power/Cable! Finish at : [10/7/2016 / 10:10:25 AM] | |
The Following User Says Thank You to papinto For This Useful Post: |
10-30-2016, 10:51 | #9 (permalink) | |
Freak Poster Join Date: May 2013 Location: algeria
Member: 1933548 Status: Offline Thanks Meter: 19 | Quote:
this cpu boot normally in Windows pack 3 please fix this problem on Windows 7 http://forum.gsmhosting.com/vbb/12092868-post6.html | |
The Following User Says Thank You to AEK@GSM For This Useful Post: |
10-30-2016, 14:56 | #10 (permalink) | |
No Life Poster Join Date: May 2016 Location: Madina, Accra, GHANA
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Quote:
