why this error come when i find the pin software version: 1.20 cable type: 1x12 (L12C) platform: MT: MT6205, MT6217-MT6235 searching adapter at COM50... adapter found, version: 4000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed error: boot initialization step #2 failed: BD 19200 fixed 19200 fixed 19200 fixed 19200 fixed error: boot initialization step #2 failed: D0 19200 fixed 19200 fixed 19200 fixed 19200 fixed error: boot initialization step #2 failed: 58 19200 fixed error: boot initialization step #3 failed: E5 19200 fixed error: boot initialization step #3 failed: 85 error: boot initialization step #2 failed: 70 19200 fixed 19200 fixed 19200 fixed error: boot initialization step #3 failed: C5 error: boot initialization step #2 failed: D0 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed error: boot initialization step #2 failed: 58 error: boot initialization step #2 failed: 52 failed to detect pins time required: 71 sec Trying to Power-On... Power On ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") help |
hello! can you power On this phone using pinfinder power? probably phone consuming too much power. have you modified your main infinity box to deliver more power to pinfinder? |
sir i can buy new infinity box combo aditon Quote:
all ok becase i plug back side cabel all ok becase i plug back side cabel i plug right way cabel then all ok cabels tow points are same because i will confuse sorry |
