05-04-2008, 13:18 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: E G Y P T Age: 48
Member: 102762 Status: Offline Sonork: 1583079 Thanks Meter: 186 | why infinity can not read this phone fw version the problem is when i press read details info i got only this Device: Autodetect 6205-6227 NOR Done Loading file v.02... backup_flash_20080504-142157.B0M.bin loaded detecting languages... Languages: En Ru Fr Cn COM1 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6217:8A00]... CPU: MT6217 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00700000 flash: 01227E22022201:29EA0000000000 checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00700000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF detecting ffs structure pass 1... .......... detect standard fat location pass #1... ............................ detect extended fat location pass #1... ........................... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... .......... detect standard fat location pass #1... ............................ detect extended fat location pass #1... .......... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 62 sec Remove/Install battery now ! |
05-05-2008, 10:07 | #5 (permalink) |
Member: 102762 Status: Offline Sonork: 1583079 Thanks Meter: 186 | when i press read general info,it says that phone should be powered on,what does this mean exactly plz coz when i do this when shuts down and operation failed |
05-05-2008, 13:01 | #6 (permalink) |
Member: 102762 Status: Offline Sonork: 1583079 Thanks Meter: 186 | i did it and this is what i got so plz give me the correct flash file that contains arabic Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6217, E00 Hardware version: YW6217_HW Software version: YW6217.Y300Z_HX_1.5" Software date: 2004.07.02 Barcode: MT012345678901234567 imei: 353016000083542 Finished, time used: 51 sec Power off phone now ! |
I can not flash this phone s5230 | uburo22 | Z3X-Team Products | 1 | 01-20-2010 04:42 |
why i can not restore IMEI for this phone after writting RPL??? | tsarkh | MT-BOX | 1 | 12-09-2007 11:10 |
why we can not use new jaf software version with UFS box??? | tsarkh | J.A.F. By Jafsupport.com | 15 | 12-08-2007 13:55 |
why can not go this web www.infinity-box.com | janjaroen | Infinity-Box | 3 | 02-16-2006 13:31 |
FW help 52.54.56.43 can help read this plz! ! ! ! | robbiesl42 | x1x to x45/x50 | 5 | 12-28-2002 11:15 |
