02-19-2010, 21:56 | #1 (permalink) |
Banned Join Date: Sep 2008 Location: Dc-serviceteam Age: 38
Member: 857234 Status: Offline Sonork: Dc Thanks Meter: 197 | Why it's remove imei write china miracle ?? now have prob imei how can solve with new ? i receive these for prob signal , it show always Emergency . after first format phone make Imei invalid , like imei option delete, i try format now i give these in log : ==== log: [19/02/2010 17:43:27] ==== COM3 [VCP0] selected module v3.07 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:5903:000B status: FF Connecting at 19200, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27warning: wrong packet cs 28 29error: detection failed (30 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 26 sec Remove/Install battery now ! have again others prob Touch srceen , after calibrate i tell imei incorrect in log. then calibration back after 2 days . log : ==== log opened: [19/02/2010 17:21:45] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v3.07 S/N: 5E25:0112 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [19/02/2010 17:21:57] ==== COM3 [VCP0] selected module v3.07 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... C231_23_08A_PCB01_GPRS_MT6223P_S00.C231_S09_1_0901 13__fullflash_20100120-114541.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:BDD7:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: C231_S09.1_090113 Version: TECHAIN23C_07B_HW 80 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 512 byte(s) read 246 byte(s) read reading data #2... 512 byte(s) read writing data... verification... verification Ok Finished, time used: 11 sec Remove/Install battery now ! |
02-19-2010, 22:42 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | We did not removed "imei" option. "Imei" button was removed by YOU !!! How to restore imei button: 1. Run Infinity-Box DongleManager: x:\Program Files\InfinityBox\DongleManager\DongleManager.exe 2. Press "Read dongle serial number (S/N)" button 3. Set "UK-Edition" option OFF (disabled) ! |
02-22-2010, 00:17 | #4 (permalink) | |
Member: 857234 Status: Offline Sonork: Dc Thanks Meter: 197 | Thank work now , *** blees infinity-team Quote:
Thank work now , *** blees infinity-team | |
china phones sim2 imei write problum | ramteja | Chinese Models & Cloned Phones | 1 | 12-20-2009 14:21 |
DON'T Write china imei IF U DON'T HV AUTHORISATION | king.of.gsm | Chinese Models & Cloned Phones | 0 | 12-18-2009 14:44 |
China 6225 IMEI write problem | muksforu | SpiderMan | 4 | 12-10-2009 17:11 |
can anyone tell me how to write IMEI to china mobile? | palav | Chinese Models & Cloned Phones | 2 | 12-09-2009 14:08 |
China Mobile IMEI write Which Method is Good META/AT ?????? | srinibas | SpiderMan | 1 | 12-07-2009 09:31 |
