Wiko lenny White screen after flash I tried flashing a backup from another wiko lenny and got a white screen.. So I added Preloader into the mix with format all and phone went dead.. So I used the testpont to wake it up. Flashed a firmware from v20 and it worked but the white screen is still there... Don't know what else to do Sent from my C1001 using Tapatalk |
change firmware's and flash with sp tool |
before doing anything do backup this will help u alot.anyways download attached LK file and flash it then post result..https://drive.google.com/file/d/0B5Z...ew?usp=sharing |
Any other solution... This is meant to be easy Sent from my C1001 using Tapatalk |
Flashed v8 same issue and phone was showing wiko display before flashing just that 8 didn't backup Sent from my C1001 using Tapatalk |
Hello, post read info logs from start before flash |
Ok Sent from my C1001 using Tapatalk |
this the only log before flash Quote:
1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 126 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111010937EE7192D5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111010937EE7192D5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x0CE0470B9B62138BD953A2942D02886C INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 3520 mV [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , a2G4 , 0xE9000000 , 3728 MiB [eMMC] : CID : 90014A483447326111010937EE7192D5 [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x20000000 , 512 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1C [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:01:38 Reconnect Power/Cable! Finish at : [10/30/2017 / 2:25:01 PM] |
Jaydi any helo Sent from my C1001 using Tapatalk |
Flash with factory updater / rom v20 , download - HERE If still the same after update, it's not SW problem. b.r. Alex |
b.r. Alex |
