06-21-2019, 17:11 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 646 | Win 10 pro after fresh instalation as i update i got error virtual machine http://forum.gsmhosting.com/vbb/f296...ected-2214128/ Virtual machine detected will close now Any solution for cm2 But after update win 10 pro any guide from team Actully my laptop not supported other windows Its dell latitude 5490 Am waiting for team reply with the right solution am not like again installation 3time already i do as update its happens but if not update than driver installation issue |
06-21-2019, 21:53 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Hi, Do not run CM2 under virtual machine. If you have some kind of VM software installed try to uninstall it. |
06-22-2019, 08:20 | #3 (permalink) |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 646 | this issue from microsoft or u r side because am not instal any other software am not instal any software just dell drivers and cm2 mtk i instal without win10 updating mouse pad not work as i update i see virtual machine error 3 time already i test it can in update which thing have |
06-22-2019, 10:18 | #6 (permalink) |
No Life Poster Join Date: Jun 2011 Location: earth
Member: 1591394 Status: Offline Thanks Meter: 551 | in search tab type optionalfeatures.exe and hit enter, disable all hyper v also disable virtualizations in BIOS |
The Following 2 Users Say Thank You to kikas112 For This Useful Post: |
06-22-2019, 11:15 | #7 (permalink) | |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 646 | am really appericiat to to help me Quote:
issue solved report is tested for win 10 pro user once more really thank sir kikas112 i hope infinity team also now know why win 10 user with 7th and 8th gen processor user got this issue ............... | |
06-22-2019, 11:35 | #8 (permalink) |
Member: 1591394 Status: Offline Thanks Meter: 551 | this is not processors fault but windows version/variant, ex professional, enterprise and probably some more have built in virtual machine. Others like mine ultimate doesnt have it happy to see its solved |
06-25-2019, 01:02 | #9 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,102 | Intel Virtualization Technology Values: Disabled, Enabled Descriptions: If this option is enabled, a Virtual Machine Monitor (VMM) can utilize the additional hardware capabilities provided by Intel Virtualization Technology. This setting should be set to Disabled to prevent security risks if operating system does not support a VMM. Note: This item is set as Disabled by default when the OS Optimized Defaults on the Restart menu is set as Disabled. This item is set as Enabled by default when the OS Optimized Defaults is set as Enabled. You need learn about New options added more and more in computer tech |
The Following 3 Users Say Thank You to rebainoor For This Useful Post: |
