07-08-2017, 14:53 | #1 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2689751 Status: Offline Thanks Meter: 17 | condor Allure A8 PGN611 7.0 MT6735 can't read pattern with CM2MTK here is the log AP] : Initial info read Ok! Brand : condor ProdName : PGN611 ProdModel : PGN611 Device : PGN611 AndroidVer: 7.0 MTKxCPU : MT6735 MTKxPRJ : WBL7519AC_0401_T8398 Wait for phone... Phone found! [ 65 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D4231589BBE0742853DF5D0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1X [eMMC] : FLASH_CID : 150100525831424D4207BE9BD0F5B385 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xE00C33E63288D416384E6CB613189C9C INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... [Error] : Bad Magic! Encrypted FS! [Info] : DP Lock not set! Done! Elapsed: 00:00:15 |
The Following User Says Thank You to mouraddza For This Useful Post: |
07-08-2017, 22:26 | #5 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | [Error] : Bad Magic! Encrypted FS! Android 6+ use encryption so not possible to read pattern.. Not cm2 problem but new security in Android Os |
