05-15-2015, 07:01 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Pakistan
Member: 775524 Status: Offline Sonork: 100.1608849 Thanks Meter: 125 | Qmobile X80 Privacy Lock reset Ok 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D42016A21CC09719B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D42016A21CC09719B [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Processing with "Safe UserData" mode SafeDetect : Done! Will reset now! Privacy Lock reset Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
The Following User Says Thank You to Nabeel khan For This Useful Post: |
06-06-2015, 21:17 | #2 (permalink) |
Freak Poster Join Date: Mar 2007 Location: South Africa/Pakistan Age: 44
Member: 476940 Status: Offline Thanks Meter: 57 | still lock Wait for phone... Phone found! [ 19 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040503A2CB7D1231 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2CB7D1231 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Privacy Lock reset Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! i done now but still locked |
The Following User Says Thank You to nasimshoukat For This Useful Post: |
