11-05-2016, 08:08 | #1 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1261483 Status: Offline Sonork: 100.1644685 Thanks Meter: 124 | world first aclatel pixi 4 (6) 9001D frp lock removed done by cm2 |
The Following 7 Users Say Thank You to Mc.Manik For This Useful Post: |
05-26-2017, 17:00 | #4 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | i av tried to reset alcatel 9001D without success using normal usb cable and EDL cable too Card found : A6C080ED , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.12 Operation : Reset Settings [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! HOW can i connect this phone |
The Following 2 Users Say Thank You to hippolyte85 For This Useful Post: |
05-26-2017, 17:18 | #5 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Make sure u have install Emergency drivers,,, download drivers frm support and install how to install drivers u can follow this theard http://forum.gsmhosting.com/vbb/f296...video-2160627/ | |
09-08-2017, 15:07 | #6 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1218511 Status: Offline Sonork: [email protected] Thanks Meter: 2 | alcatel 9001d reset frp done with .... nad edl cable Last edited by InfinityHelp; 09-09-2017 at 16:18. Reason: advertizing removed |
09-09-2017, 16:19 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | You can buy Infinity-Box/Dongle here - https://www.infinity-box.com/buy/ |
01-19-2019, 10:00 | #12 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1135630 Status: Offline Sonork: [email protected] Thanks Meter: 2 | connect wifi,back then add wifi network and write anything long tap then share then long tap gmail,then notification on app setting and then click manage account next about build varson then tap 7time after actibate devoloper then oem unlock activate,back reset then frp ok |
The Following 2 Users Say Thank You to mdhanif For This Useful Post: |
