08-28-2015, 19:38 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | World First : MediaTek MT6595 FULL and REAL support ;) So, lets start with MT6595. While others show read info log , or show nothing, just empty "mtxxx" support, without any propper tests and e.t.c. , We make all things, which should be and sure - all they are working. Read Full info ( including HW, Modem, Langs and e.t.c. ) Code: Operation : Check / Read Info [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004257424333520259EA4F759109 DA Stat : v3.2 on BBID : 0x8C DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : R3CBW [eMMC] : FLASH_CID : 1501004257424333520259EA4F759109 [eMMC] : FLASH_LEN : 0x0000000747C00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : x2eu ProdModel : Lenovo X2-EU Device : X2-EU AndroidVer: 4.4.2 MTKxCPU : MT6595 MTKxPRJ : X2-EU_ROW_S117_1410101350 MODEM : BaseBand : MT6595_S00_X2_EU_V26_1_lwg_n EXTRA : LCD [0] : nt35595_fhd_dsi_vdo_lg LCD [1] : otm1902a_fhd_dsi_cmd_tianma LCD Res : 1920x1080 TOUCH [0] : S3528 CAM [0] : imx214_mipi_raw CAM [1] : ov5693_mipi_raw MODEM : mt6595k95_hspa_lwg_x2eu LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB bn_BD ka_GE Done! Elapsed: 00:00:15 Reconnect Power/Cable! Result is same as factory one. It fully compatible with SPFT World first and e.t.c. Code: Operation : Read Flash [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004257424333520259EA4F759109 DA Stat : v3.2 on BBID : 0x8C DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : R3CBW [eMMC] : FLASH_CID : 1501004257424333520259EA4F759109 [eMMC] : FLASH_LEN : 0x0000000747C00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Lenovo ProdName : x2eu ProdModel : Lenovo X2-EU Device : X2-EU AndroidVer: 4.4.2 MTKxCPU : MT6595 MTKxPRJ : X2-EU_ROW_S117_1410101350 [Read Ok] : preloader_x2eu.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : preload.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6595 / V1.1.2 / x2eu / EMMC FW Size : 1897 MiB Scatter saved to : E:\MT6595__Lenovo__Lenovo X2-EU__X2-EU__4.4.2__X2-EU_ROW_S117_1410101350\ All done! Done! Elapsed: 00:07:36 Reconnect Power/Cable! World first and e.t.c. Code: Scatter Load Ok , BaseBand : MT6595 , Project : x2eu , Storage : EMMC Files found : 10 , Set to Flash : 9 Ready to Flash! Operation : Flash [ v1.27 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004257424333520259EA4F759109 DA Stat : v3.2 on BBID : 0x8C DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : R3CBW [eMMC] : FLASH_CID : 1501004257424333520259EA4F759109 [eMMC] : FLASH_LEN : 0x0000000747C00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6595 , Project : x2eu , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : Only one records found, and determined as universal BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 1 Erase : 0x0000000001C80000-0x0000000744F00000 Flash Pre-Erase Done, time used : 00:00:03 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_x2eu.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0010 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : PRELOAD Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:04:11 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : SECRO Verify Passed : LOGO Verify Passed : PRELOAD Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:04 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:33 Reconnect Power/Cable! World first and e.t.c. It REALLY work Code: Operation : Repair Security [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004257424333520259EA4F759109 DA Stat : v3.2 on BBID : 0x8C DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : R3CBW [eMMC] : FLASH_CID : 1501004257424333520259EA4F759109 [eMMC] : FLASH_LEN : 0x0000000747C00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 866156020xxxxxx Set IMEI [00] : 099644327654346 Prepare finished. Security check required! Wait for phone... Phone found! [ 63 ] Sync... PostCheck Ok! Repair done! Done! Elapsed: 00:00:54 Reconnect Power/Cable! After "Security Repair" it can fail to"DL image fail"! (Lenovo will fail to this mode 100%) Use "Fix DL" option to fix that! Fix DL Errors Code: Operation : Fix DL Errors [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004257424333520259EA4F759109 DA Stat : v3.2 on BBID : 0x8C DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : R3CBW [eMMC] : FLASH_CID : 1501004257424333520259EA4F759109 [eMMC] : FLASH_LEN : 0x0000000747C00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! World first and e.t.c. Code: Operation : SP Unlock [ v1.27 ] Mode : Read Codes 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004257424333520259EA4F759109 DA Stat : v3.2 on BBID : 0x8C DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : R3CBW [eMMC] : FLASH_CID : 1501004257424333520259EA4F759109 [eMMC] : FLASH_LEN : 0x0000000747C00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM [1] codes : [1] Level , [Locked] : False [2] Level , [Locked] : False [3] Level , [Locked] : False [4] Level , [Locked] : False [5] Level , [Locked] : False [6] Level , [Locked] : False [7] Level , [Locked] : False SIM [2] codes : [1] Level , [Locked] : False [2] Level , [Locked] : False [3] Level , [Locked] : False [4] Level , [Locked] : False [5] Level , [Locked] : False [6] Level , [Locked] : False [7] Level , [Locked] : False Done! Elapsed: 00:00:20 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004257424333520259EA4F759109 DA Stat : v3.2 on BBID : 0x8C DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : R3CBW [eMMC] : FLASH_CID : 1501004257424333520259EA4F759109 [eMMC] : FLASH_LEN : 0x0000000747C00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! World first and e.t.c. Code: Operation : Read PatternLock [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004257424333520259EA4F759109 DA Stat : v3.2 on BBID : 0x8C DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : R3CBW [eMMC] : FLASH_CID : 1501004257424333520259EA4F759109 [eMMC] : FLASH_LEN : 0x0000000747C00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 27538 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 12547 Done! Elapsed: 00:00:50 Reconnect Power/Cable! World first and e.t.c. Code: Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004257424333520259EA4F759109 DA Stat : v3.2 on BBID : 0x8C DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : R3CBW [eMMC] : FLASH_CID : 1501004257424333520259EA4F759109 [eMMC] : FLASH_LEN : 0x0000000747C00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSA Ok! LSSW Ok! LSSS Ok! LSSG Ok! Security Settings : Clear Ok! [Info] : Android 5.x / MT67xx : If phone stuck on "Logo" 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:20 Reconnect Power/Cable! World first and e.t.c. It save data in 4 different formats, including apple,google,vcf,and human readable. Code: Operation : Read UserData [ v1.27 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004257424333520259EA4F759109 DA Stat : v3.2 on BBID : 0x8C DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : R3CBW [eMMC] : FLASH_CID : 1501004257424333520259EA4F759109 [eMMC] : FLASH_LEN : 0x0000000747C00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 10 TXT Saved to : C:\Infinity\CM2\CM2MTK\PhData\MT6595_PhoneBook.txt Write : 10 CSV Saved to : C:\Infinity\CM2\CM2MTK\PhData\MT6595_PhoneBook.csv Write : 10 VCF Saved to : C:\Infinity\CM2\CM2MTK\PhData\MT6595_PhoneBook.vcf Write : 10 VCFv3 Saved to : C:\Infinity\CM2\CM2MTK\PhData\MT6595_PhoneBook_v3.vcf Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following 22 Users Say Thank You to JayDi For This Useful Post: |
08-29-2015, 14:13 | #4 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
In this case meaning first, only and unique and so on. But your one also good in that case | |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
01-03-2016, 07:39 | #7 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2075571 Status: Offline Thanks Meter: 3 | Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT target! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! this error is comming (infocus M530) problam is password Last edited by ynr@srd; 01-03-2016 at 07:46. |
01-03-2016, 09:57 | #8 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Infocus phones are not supported as they have own DA, wait for update. Br. Infinity Box Support Team. | |
01-03-2016, 11:41 | #9 (permalink) | |
