03-12-2017, 11:41 | #1 (permalink) |
Freak Poster Join Date: Aug 2016 Location: out of world
Member: 2609423 Status: Offline Sonork: 1660954:2007 Thanks Meter: 360 | world first mi note 4 mi account remove done by cm2 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! MIAccount reset passed! Normal reset : > Select "FORCED FIX" or "REPAIR" in FMT settings, press "Format FS / Reset Settings" > PowerOn device and use. IF Device stuck on black screen with cable - use another FMT > Not all devices supported yet! (tested on Hydrogen,Land,Redmi2) Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
03-14-2017, 06:28 | #4 (permalink) |
Member: 2609423 Status: Offline Sonork: 1660954:2007 Thanks Meter: 360 | steps 1* remove the battery (if freezed in edl mode) 2*boot to edl mode 3* then ope tool and choose reset mi account thanks waiting for replay |
The Following 2 Users Say Thank You to applebricks For This Useful Post: |
05-09-2017, 06:56 | #10 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2093296 Status: Offline Thanks Meter: 9 | MI NOTE 4 (2016100) pattern lock succcesfully ... :via recovery mode put your phone recovery mode connect to pc open Rb soft tool 1.6 tab to :recovery slide lode then format.. |
08-17-2017, 12:03 | #12 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Nepal,kathmandu
Member: 1988630 Status: Offline Sonork: 100.1684003 Thanks Meter: 312 | great cm2 mi 2016100 mi account remove done only 33sec.... Card found : B4F319DE , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15 Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 625 [MSM8953] ID_BLOCK_S : 03587A2F ID_BLOCK_I : 000460E1 ID_BLOCK_L : 2F68FBD7656C54078EC26ED94D39C1F6 ID_BLOCK_L : 20DC960DC0EBFB332CBF544F289E4A3F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:02:45 Reconnect Power/Cable! Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 625 [MSM8953] ID_BLOCK_S : 03587A2F ID_BLOCK_I : 000460E1 ID_BLOCK_L : 2F68FBD7656C54078EC26ED94D39C1F6 ID_BLOCK_L : 20DC960DC0EBFB332CBF544F289E4A3F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Brand : xiaomi ProdName : mido ProdModel : Redmi Note 4 Device : mido AndroidVer: 6.0.1 Manufact. : Xiaomi SysPatch : MMB29M DevComTime: 6/2/2017 1:53:58 PM QLMxCPU : MSM8953 USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:33 Reconnect Power/Cable! Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 625 [MSM8953] ID_BLOCK_S : 03587A2F ID_BLOCK_I : 000460E1 ID_BLOCK_L : 2F68FBD7656C54078EC26ED94D39C1F6 ID_BLOCK_L : 20DC960DC0EBFB332CBF544F289E4A3F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! MIAccount reset passed! Complete reset : > If device lock after WiFi - use RESET MI APP > PowerOn device, NOT power WiFi, SIM and etc. Make device setup > Reset MI APP. Device will not have MIServices anymore Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to adfd For This Useful Post: |
08-17-2017, 12:03 | #13 (permalink) |
Member: 1988630 Status: Offline Sonork: 100.1684003 Thanks Meter: 312 | great cm2 mi 2016100 mi account remove done only 33sec.... Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 625 [MSM8953] ID_BLOCK_S : 03587A2F ID_BLOCK_I : 000460E1 ID_BLOCK_L : 2F68FBD7656C54078EC26ED94D39C1F6 ID_BLOCK_L : 20DC960DC0EBFB332CBF544F289E4A3F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! MIAccount reset passed! Complete reset : > If device lock after WiFi - use RESET MI APP > PowerOn device, NOT power WiFi, SIM and etc. Make device setup > Reset MI APP. Device will not have MIServices anymore Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
11-12-2017, 11:06 | #14 (permalink) | |
Freak Poster Join Date: Dec 2014 Location: nepal,lalitpur
Member: 2306223 Status: Offline Sonork: 1660968:1234 Thanks Meter: 117 | Quote:
http://i66.tinypic.com/nlyc2c.jpg try this pinout...for 2016100 3gb 32gb mi note 4 | |
01-06-2018, 02:03 | #15 (permalink) |
Freak Poster Join Date: Jan 2016
Member: 2515283 Status: Offline Sonork: 100.1671440 Thanks Meter: 84 | why waste your time,All problems reesolved by UMT, see complete video Don't forget to press thanks meter |
The Following User Says Thank You to rupesh2015 For This Useful Post: |
