Old 09-18-2018, 12:51   #1 (permalink)
misal's Avatar
Member: 185854
Sonork: 100.1592083
Thanks Meter: 286
world first oppo f9 (cph-1823) demo reset Done with cm2 dongle
[FL] : Total size : 0x10D000000 [ 4.20 GB ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM77)
MODE : BOOTROM
PORT : 77
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+SEL
BROM : BOOTROM
MODE : Oppo : F7 | Manual : Disabled
BROM : SLA
BROM : SLA Passed!
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_BR_HIGH.bin
AGENT : Found MT6771
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
EMI : CNT : 000E
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 90014A484347386134A248BBC5F91521
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0xE8F800000 [ 58.24 GB ]
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : AAF4B594BCADBE8C6FF8926BDE4A6F
DA : USB : HIGH-SPEED
Boot done!
[FL] : HW verification passed!
[FL] : RePartition
[FL] : RePartition Ok!
[FL] : Flashing now ...
[FL] : Flashing finished!
Done!
Elapsed: 00:02:27
Reconnect Power/Cable!
The Following 8 Users Say Thank You to misal For This Useful Post:
Old 09-18-2018, 15:36   #2 (permalink)
Member: 1189070
Thanks Meter: 167
which option you select flashing or wipe ?
Old 09-18-2018, 16:34   #3 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
Flash system and logo from working set
But this will be temporary solution
If customer update set via OTA demo will come back
Permanent solution is flash set with factory firmware
The Following User Says Thank You to kamal_singla For This Useful Post:
Old 09-18-2018, 20:25   #4 (permalink)
misal's Avatar
Member: 185854
Sonork: 100.1592083
Thanks Meter: 286
No bro. It's permanent solution for oppo f9 pro mtk 6771.........
Old 09-18-2018, 23:28   #5 (permalink)
Member: 2211790
Thanks Meter: 5,118
Update from setting and check you will let know... :P
Old 09-19-2018, 08:58   #6 (permalink)
Member: 2688257
Sonork: 100.1671380
Thanks Meter: 104
Card found : C2D2E13E , v0136
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4
Operation : Identify [ v2.00 r4 ]
PTFN : MediaTek USB Port (COM43)
MODE : BOOTROM
PORT : 43
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 000E
EMMC: 150100444836444142024C72C40475E5
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DH6DAB
EMMC:
RPMB : 0x01000000 [ 16.00 MB ]
RNID : B95E1C53F5434B45B191706E109BCBD7
Boot done!
Patch Level : O11019
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-07-05
Product Manfct : OPPO
Build Time : 1533986838
Product Brand : OPPO
Product Model : CPH1823
Product Info : CPH1823
Product Device : CPH1823
Product Name : CPH1823
SW OTA Version : CPH1823EX_11.S.04_0040_201808111836
Display ID : CPH1823EX_11_S.04_180811
Kernel Info : 4.4.95-G201808111836
USERDATA : ENCRYPTED
Done!
Elapsed: 00:00:24
Operation : Write Flash [ v2.00 r4 ]
Repartition : Enabled
Flash Verify : Disabled
Pre-Erase : Enabled
Verify HW/SW : Enabled
XData Backup : Disabled
Files :1
[FL] : Set : system.bin
MODE : BOOTROM
PORT : 43
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 000E
EMMC:
Boot done!
Done!
Elapsed: 00:02:13
Special thanks
misal
Old 09-19-2018, 13:03   #7 (permalink)
Member: 307225
Thanks Meter: 59
Where From We Get This File ?
Old 09-19-2018, 13:25   #8 (permalink)
Member: 307225
Thanks Meter: 59
Getting This Error While Write System File.
Pre-Erase    : Enabled
Files :2
[FL] : Set : logo.bin
[FL] : Set : system.img
[FL] : Total size : 0xCC0962B8 [ 3.19 GB ]
PTFN : MTK USB Port (COM14)
MODE : BOOTROM
PORT : 14
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV :
     EMI : SRC :
     EMI : CNT : 0000
     DA : SETUP EMI PARAMS FAILED!
  ERROR : ERROR
Error : Fail to init protocol!
Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device!
Old 09-23-2018, 14:48   #9 (permalink)
Member: 888420
Sonork: 100.1611861
Thanks Meter: 394
PTFN : MediaTek USB Port (COM7)
MODE : BOOTROM
PORT : 7
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV :
EMI : SRC :
EMI : CNT : 0000
ERROR : ERROR
Someone Solved this ????
Old 09-23-2018, 16:21   #10 (permalink)
pshycoboy's Avatar
Member: 1597314
Thanks Meter: 116
learn log,set emi config with other.try oneby one,emi 0 if failled,try emi 1 if error try emi 2.just try and post result.
Old 09-24-2018, 07:55   #11 (permalink)
Member: 888420
Sonork: 100.1611861
Thanks Meter: 394
PTFN : MediaTek USB Port (COM3)
MODE : BOOTROM
PORT : 3
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV :
EMI : SRC :
EMI : CNT : 0000
ERROR : ERROR
STILL SAME ANYONE SOLVE THIS??
Old 09-24-2018, 10:06   #12 (permalink)
Member: 307225
Thanks Meter: 59
I Got Success By Selecting Oppo A3
Old 09-24-2018, 10:58   #13 (permalink)
Member: 888420
Sonork: 100.1611861
Thanks Meter: 394
I got still same issue
Old 09-25-2018, 05:53   #14 (permalink)
Member: 307225
Thanks Meter: 59
Why You Want To Flash The Phone ?
What Is Problem In Your Phone Can You Please Post Details.
Old 10-04-2018, 22:25   #15 (permalink)
Member: 1061473
Sonork: 1612680
not working
Infinity Chinese Miracle-2 MTK/Mediatek v2.00 r4
OPPO f9 after format restart problem
Page generated in 0.24202 seconds with 8 queries
