[WorldFirst] SC7731 Android 5.x FRP remove! Code: Operation : Format File System [ v1.07 ] |
Hardware:sc7731c Board:sp7731cea CPU ABI:armeabi-v7a Manufacturer:xtouch Model:e2 Android Ver:5.1 bootloader ver:unknown USB config:mtp,adb User:jks Baseband ver:tm_base_15b_w16.09.4|sc7731g_cp0_modem|02-24-2016 17:56:34 Build number:e2-5.1-tecsync-20160621-v1 ID:lmy47d Region:us Language:en Chipset:sc8830 boot failed ver 1.21 |
Start from reading user manual. It helps alot. |
wish user manual reading ?? |
Phone found! [ 71 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable boot failed FDL Ready! |
Archos 45B NEON - Android 5.0.1- F.R.P. Done! 1. Open Cm2spd v1.21 tool 2. Set CPU "SC7730 SC7731 EMMC Android5.x" 3. Set "Alternative LDR Mode" 4. Go to "Service" Tab, and pick in "CLEAR FRP" 5. The battery is unremovable in this phone, only shut down phone, press vol-+ and connect usb cable: Quote:
I Install Spreadtrum drivers from infinity support use windows xp , windows vista, but no solution to reset frp in archos 45b, stil MTP drivers problem , and program dont find this phone how to solve this ? |
