06-20-2008, 12:00 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 742276 Status: Offline Thanks Meter: 9 | wrong packet cs when trying to format ffs I have this error when trying to format ffs safe. I already pressed the power button from beginning to end, but the error still there. Help me solve this problem please.. Thanks. COM8 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:EC0A:AA3A Connecting, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 26 sec Remove/Install battery now ! |
06-20-2008, 12:04 | #2 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Dear friend, First - Full charged the battry Second - Try to fix hold on the battry while FFS Main point in this error is u during this process barrty power is cut. That's why this error show. Post result. |
06-20-2008, 13:08 | #3 (permalink) |
Member: 742276 Status: Offline Thanks Meter: 9 | I don't use battery with the phone. I use spiderman box to connect/find the pin, and then operate with infinity. So the power comes from the box. Do you think there's problem with the power from spiderman? because i can read eeprom and full flash using the same set up. |
ALFATEL H2 wrong packet cs Error on Infinity | mswmkm | Infinity-Box | 2 | 11-08-2009 10:44 |
Warning: Wrong packet cs | drjaved_akhter | Infinity-Box | 1 | 09-26-2009 14:14 |
wrong packet cs need help????? | leomuns | Infinity-Box | 1 | 06-13-2008 15:44 |
N95i dead when trying to format | patric | Infinity-Box | 5 | 06-08-2008 11:33 |
