Old 04-26-2017, 05:52   #1 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 338
zte blade A112 trying unlock
hi trying to unlock zte mtk phone giving me this error
Wait for phone...
Phone found! [ 21 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 510001154D533237EFF100420F279DB4
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMS27
[eMMC] : FLASH_CID : 150100513732534D4200F1EFB49D830F
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID    : 0xFD786EC187CF881DFDD005BA1FD60552
INT RAM    : 0x00020000
EXT RAM    : 0x40000000 [1 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
USBDL : Init HSUSB Ok
SIM Lock Status : Locked!
Unlocking now ...
Error while unlocking, somethig went wrong!
Operation Failed
Elapsed: 00:00:29
Reconnect Power/Cable!
Old 04-26-2017, 06:51   #2 (permalink)
Member: 2195211
Thanks Meter: 4,294,967,295
tick on read info and read code with cm2.. your problem will be solved...
Old 04-26-2017, 06:52   #3 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 338
Yes I can read code I already did. It direct unlock not working
Old 10-28-2017, 07:18   #4 (permalink)
Member: 2307390
Hey bro,
you can unlock with Furious Gold using OTSmart just select ZTE Blade A110 and direct unlock and plug in phone switched off and voila UNLOCKED.....both phones have same CPU
Old 05-22-2018, 09:14   #5 (permalink)
Member: 2547209
how can i enter unlock code on phone
Old 05-22-2018, 09:31   #6 (permalink)
Member: 2839224
Hi! Mu phone ZTE A5 Pro imei 860060035555237 ; imei 860060035955239 operator Megafon Russia Give me unlock code pliase! Thank you much in advance!
Old 05-22-2018, 10:10   #7 (permalink)
Haicha's Avatar
Member: 330579
Thanks Meter: 67,515
Request in Correct Section.......
Page generated in 0.21592 seconds with 8 queries
