xcell zoom da file need Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM33) MODE : PRELOADER PORT PORT : 33 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! not frp remove pl help |
not solve same problem and modle is xcell zoom in frp ic MT 6737M |
I have also same set but set is stuck on logo i need DA file of same modle https://i.ibb.co/ZYpXTHd/Untitled.jpg |
xcell zoom frp lock remove without pc |
Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
Xcell ZOOM file needed plzzz send link |
XCell Zoom Flash file link http s://jameelahmed91.blogs pot.co m/2020 /02/xcell- zoom-flash-file-free- wo-pass.ht ml Note: remove space b/w link |
Xcel zoom connect by cm2 mt2 module Xceel zoom connect vol- downkey press then cm2 mt2 module 2.0.6 version |
:p |
The Firmware is readed from XCell Zoom working device with Infinity CM2 MT2 2.5 module with 1844 Base. XCell Zoom do not require any custom DA or AUTH file just press vol - vol + buttons and perform your desired operation like Read/Write Flash, Factory Reset/Format, Repair SEC etc. |
