11-19-2022, 02:11 | #1 (permalink) |
Major Poster Join Date: Jan 2022 Location: Kawalan, Papua New guinea Age: 47
Member: 3005248 Status: Offline Thanks Meter: 11 | Nokia G20 TA-1336 Failed to Start Logs below: 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM7) MODE: BOOTROM PORT: 7 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: MEID: 678F0DFA1CB7062F92CEE366344EB54D BROM: SecLevel: 0x000000E7 BROM: SecMode : SBC+SLA+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 5B51E8E2F8ED6D793A688CBC8A02D487A970292408BC0DA1B8 7CE2033AD2B9A6 BROM: Sending FireFly FireFly: Starting... FireFly: Init Core FireFly: Core init done FireFly: Running : v05.05.05 on MT6765 FireFly: eMMC init passed EMMC: CSD: D0FFFF329F5903FFFFFFFFEF9640002D EMMC: CSD: TEMP_WRITE_PROTECT: False EMMC: CSD: PERM_WRITE_PROTECT: False EMMC: CID: 880103534C44363447608A323BB058F5 EMMC: VEN: Foresee : OEM: 3 : ID: 534C44363447 : PRV: 0x60 EMMC: VEN: Foresee : SLD64G EMMC: SNN: 2318547888 ( 0x8A323BB0 ) MF: 5/2021 EMMC: EXTCSD: rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [CONFIG] : 0x50 0x02 0x01 EMMC: EXTCSD [PARTITION_CONFIG] : 0x50 EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [RST_N_FUNCTION] : 0x01 EMMC: EXTCSD [PART_S_COMPLETED] : False EMMC: EXTCSD [SIZE] : Market : 64 GB EMMC: EXTCSD [SIZE] : Actual : 0xE67800000 [ 57.62 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : Not defined EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0xE67800000 [ 57.62 GB ] DA: USB: HIGH-SPEED Boot done SW : Nokia/Ronin_00WW/RNN_sprout:11/RP1A.200720.011/00WW_1_100:user/release-keys Product Brand : Nokia Product Model : Nokia G20 Product Name : Ronin_00WW Product Device : RNN_sprout Patch Level : RP1A.200720.011 Display ID : 00WW_1_100 SW Version : 00WW_1_100 Product Info : RNN_sprout Product Model : 00WW Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-06-05 Build Time : 08.06.2021 CPU : arm64-v8a,armeabi-v7a,armeabi CPU : armeabi-v7a,armeabi CPU : arm64-v8a SW : full_T99653AA1-user 11 RP1A.200720.011 mp1V44 release-keys Product Board : MT6765 Board Platform : mt6765 Product Manfct : HMD Global USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) Verify device config... Ok No loaders to verify NVRAM: Items: 0xA0 Size: 0x08D053 NVRAM: State: Ok NVRAM: SecLv: Vendor Signed INFO : WiFi MAC: AA0036004400 INFO : BlTh MAC: C010B1CF730E INFO : IMEI[1]: 358846152189xxx INFO : IMEI[2]: 3588461521895xx Scan preloader... Preloader: EMI: MT6765 preloader_t99653aa1.bin with 3 memory type(s) supported EMI[00] : DRAM : LP_DDR4X : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 512.00 MB ] EMI[01] : DRAM : LP_DDR4X : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 4.00 GB ] EMI[02] : DRAM : LP_DDR4X : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 4.00 GB ] Preloader exist: C:\Program Files (x86)\New folder\CM2MT2\backup\PRELOADER\preloader_t99653aa1 .bin Verify backup\PRELOADER\preloader_t99653aa1.bin [8f650935]... Exist Ok Done Elapsed: 00:02:22 Operation : Reset Settings/Format FS [ v2.37 ] Mode: FACTORY RESET ( WIPE ) 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM7) MODE: BOOTROM PORT: 7 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: MEID: 678F0DFA1CB7062F92CEE366344EB54D BROM: SecLevel: 0x000000E7 BROM: SecMode : SBC+SLA+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 5B51E8E2F8ED6D793A688CBC8A02D487A970292408BC0DA1B8 7CE2033AD2B9A6 BROM: Sending FireFly FireFly: Starting... FireFly: Init Core FireFly: Core init done FireFly: Running : v05.05.05 on MT6765 FireFly: eMMC init passed EMMC: CSD: D0FFFF329F5903FFFFFFFFEF9640002D EMMC: CSD: TEMP_WRITE_PROTECT: False EMMC: CSD: PERM_WRITE_PROTECT: False EMMC: CID: 880103534C44363447608A323BB058F5 EMMC: VEN: Foresee : OEM: 3 : ID: 534C44363447 : PRV: 0x60 EMMC: VEN: Foresee : SLD64G EMMC: SNN: 2318547888 ( 0x8A323BB0 ) MF: 5/2021 EMMC: EXTCSD: rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [CONFIG] : 0x50 0x02 0x01 EMMC: EXTCSD [PARTITION_CONFIG] : 0x50 EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [RST_N_FUNCTION] : 0x01 EMMC: EXTCSD [PART_S_COMPLETED] : False EMMC: EXTCSD [SIZE] : Market : 64 GB EMMC: EXTCSD [SIZE] : Actual : 0xE67800000 [ 57.62 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : Not defined EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0xE67800000 [ 57.62 GB ] DA: USB: HIGH-SPEED Boot done Verify device config... Ok No loaders to verify Format Ok: USERDATA Done Elapsed: 00:00:48 Need flash file to reflash. Br, Last edited by mamobile5; 11-19-2022 at 02:17. |
11-19-2022, 09:38 | #2 (permalink) |
Member: 3005248 Status: Offline Thanks Meter: 11 | Issue Solved thanks to this thread here: https://forum.gsmhosting.com/vbb/f29...flash-2996919/ Logs below that solve the issue: Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.37 Load IDBase v723487 Ok Update configuration... Configuration [12060] updated Load IDBase v723487 Ok Load: C:\Downloads\Compressed\MT6765__HMD_Global__00WW__ 11__00WW_1_100_SP01__RP1A.200720.011__RNN_sprout\M T6765__HMD_Global__00WW__11__00WW_1_100_SP01__RP1A .200720.011__RNN_sprout\MT6765_Android_scatter.txt Created by Infinity-Box (c) 2021 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Product Brand : Nokia Product Model : Nokia G20 Product Name : Ronin_00WW Product Device : RNN_sprout Patch Level : RP1A.200720.011 Display ID : 00WW_1_100_SP01 Product Info : RNN_sprout Product Model : 00WW Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-07-05 Build Time : 15.07.2021 Product Board : MT6765 Board Platform : mt6765 Product Manfct : HMD Global Preloader [HW DEV] Info: EMI: MT6765 preloader_t99653aa1.bin with 3 memory type(s) supported EMI[00] : DRAM : LP_DDR4X : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 512.00 MB ] EMI[01] : DRAM : LP_DDR4X : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 4.00 GB ] EMI[02] : DRAM : LP_DDR4X : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 4.00 GB ] Operation : Write Flash [ v2.37 ] [+] Repartition [-] Flash Verify [+] Reg.Pre-Erase [+] Verify HW/SW [+] SData Backup [-] Safe UserData [-] Flash Format Files: 32 [FL]: C:\Downloads\Compressed\MT6765__HMD_Global__00WW__ 11__00WW_1_100_SP01__RP1A.200720.011__RNN_sprout\M T6765__HMD_Global__00WW__11__00WW_1_100_SP01__RP1A .200720.011__RNN_sprout\ [FL]: Set: logo.bin [FL]: Set: md1rom.img [FL]: Set: spmfw.img [FL]: Set: tinysys-scp.bin [FL]: Set: sspm.img [FL]: Set: gz.img [FL]: Set: lk.bin [FL]: Set: boot.img [FL]: Set: dtbo.img [FL]: Set: tz.img [FL]: Set: vbmeta.img [FL]: Set: vbmeta_system.img [FL]: Set: vbmeta_vendor.img [FL]: Set: wt_custom.img [FL]: Set: logo.bin [FL]: Set: md1rom.img [FL]: Set: spmfw.img [FL]: Set: tinysys-scp.bin [FL]: Set: sspm.img [FL]: Set: gz.img [FL]: Set: lk.bin [FL]: Set: boot.img [FL]: Set: dtbo.img [FL]: Set: tz.img [FL]: Set: vbmeta.img [FL]: Set: vbmeta_system.img [FL]: Set: vbmeta_vendor.img [FL]: Set: wt_custom.img [FL]: Set: oem.img [FL]: Set: elabel.img [FL]: Set: super.img [FL]: Set: userdata.img [FL]: Total size: 0x18A140D48 [ 6.16 GB ] 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM37) MODE: BOOTROM PORT: 37 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: MEID: 678F0DFA1CB7062F92CEE366344EB54D BROM: SecLevel: 0x000000E7 BROM: SecMode : SBC+SLA+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 5B51E8E2F8ED6D793A688CBC8A02D487A970292408BC0DA1B8 7CE2033AD2B9A6 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI not found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\Program Files (x86)\New folder\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_ DA.bin AGENT : [a3e34f97] C:\Downloads\Compressed\MT6765__HMD_Global__00WW__ 11__00WW_1_100_SP01__RP1A.200720.011__RNN_sprout\M T6765__HMD_Global__00WW__11__00WW_1_100_SP01__RP1A .200720.011__RNN_sprout\preloader_t99653aa1.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA : AGENT started DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized EMMC: CID: 880103534C44363447608A323BB058F5 EMMC: VEN: Foresee : OEM: 3 : ID: 534C44363447 : PRV: 0x60 EMMC: VEN: Foresee : SLD64G EMMC: SNN: 2318547888 ( 0x8A323BB0 ) MF: 5/2021 EMI: MT6765 preloader_t99653aa1.bin with 3 memory type(s) supported EMI[00] : DRAM : LP_DDR4X : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 512.00 MB ] EMI[01] : DRAM : LP_DDR4X : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 4.00 GB ] EMI[02] : DRAM : LP_DDR4X : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 4.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed DA : BOOT to 2nd DA... DA : 2ND stage confirmed DA : SYNC with DA passed DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID: 880103534C44363447608A323BB058F5 EMMC: VEN: Foresee : OEM: 3 : ID: 534C44363447 : PRV: 0x60 EMMC: VEN: Foresee : SLD64G EMMC: SNN: 2318547888 ( 0x8A323BB0 ) MF: 5/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE67800000 [ 57.62 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: D012DC0928D092D8D973E4537CC5EF2 DA: USB: HIGH-SPEED Boot done [FL]: HW verification passed Verify device config... Ok No loaders to verify [FL]: Pre-Flash backup Backup critical data [18] to C:\Program Files (x86)\New folder\CM2MT2\backup\MT6765__678F0DFA1CB7062F92CEE 366344EB54D\ [17] Read: NVRAM [7] Read: NVDATA [15] Read: PROINFO [6] Read: NVCFG [10] Read: PROTECT1 [1] Read: PGPT [13] Read: PERSIST [0] Read: PRELOADER Done [FL]: Pre-Flash backup passed SEC_DL: False (RAPHAEL) SEC_ID: 0x494E46494E495459424F584245535432 [FL]: Pre-Erase Erase: 0x0000000000000000 0x0000000001688000 Erase: 0x0000000003688000 0x000000000769A000 Erase: 0x000000000C000000 0x0000000000800000 Erase: 0x000000000F800000 0x0000000000200000 Erase: 0x000000000FD00000 0x0000000000080000 Erase: 0x0000000013D80000 0x000000026CA80000 [FL]: RePartition [FL]: RePartition Ok [FL]: Flashing now... Write: LOGO_A Write: MD1IMG_A Write: SPMFW_A Write: SCP_A Write: SSPM_A Write: GZ_A Write: LK_A Write: BOOT_A Write: DTBO_A Write: TEE_A Write: VBMETA_A Write: VBMETA_SYSTEM_A Write: VBMETA_VENDOR_A Write: WT_CUSTOM_A Write: LOGO_B Write: MD1IMG_B Write: SPMFW_B Write: SCP_B Write: SSPM_B Write: GZ_B Write: LK_B Write: BOOT_B Write: DTBO_B Write: TEE_B Write: VBMETA_B Write: VBMETA_SYSTEM_B Write: VBMETA_VENDOR_B Write: WT_CUSTOM_B Write: OEM Write: ELABEL Write: SUPER Write: USERDATA UltraFlash: OK SEC_DL: False (RAPHAEL) SEC_ID: 0x494E46494E495459424F584245535432 [FL]: RePartition [FL]: RePartition Ok [FL]: Flashing finished Done Elapsed: 00:04:29 Reconnect Power/Cable now Br, |
The Following User Says Thank You to mamobile5 For This Useful Post: |
