02-23-2016, 08:17 | #1 (permalink) |
Freak Poster Join Date: Dec 2006 Location: India, Rajasthan,kota
Member: 411636 Status: Offline Thanks Meter: 10 | xiaomi mi HM Note 1w error i received this set on hang on logo condition, and try to flash but now set is dead, trying in CM2 but error here is log Card found : S/N : 02464F3F , v0130 Chinese Miracle II [MTK module] v 1.41 Scatter Load Ok , BaseBand : MT6592 , Project : MTDTtest , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.41 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847326404050174C70D6177 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A483847326404050174C70D6177 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 4F65A4C0C033B1C5D55A92A5C2E22A70 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6592 , Project : MTDTtest , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Preloader Check failed, looks like damaged! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! plz. any help. Thanks |
The Following User Says Thank You to Taturi For This Useful Post: |
02-23-2016, 08:35 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Logs shows phone already dead. Make sure firmware is good which you are trying to write, by log it seems preloader damaged in firmware which you are trying to write. Try downloading new good firmware. Br. Infinity Box Support Team. |
02-23-2016, 17:36 | #3 (permalink) |
Major Poster Join Date: Mar 2008 Location: indonesia
Member: 716073 Status: Offline Thanks Meter: 17 | HM NOTE 1W TESTED LONG TIME AGO Start at : [12/29/2015 / 10:25:14 PM] Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A48384732640405018ACDE46101 DA Stat : v4.2 on BBID : 0x8A DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC DRAM Init Ok , 0x40000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A48384732640405018ACDE46101 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Init HSUSB Ok! Brand : Xiaomi ProdName : lcsh92_wet_jb9 ProdModel : HM NOTE 1W Device : lcsh92_wet_jb9 AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : ALPS.KK1.MP1.V2.46 [Read Ok] : preloader_lcsh92_wet_jb9.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6592 / V1.1.2 / lcsh92_wet_jb9 / EMMC FW Size : 838 MiB Scatter saved to : G:\InfinityBox\CM2MTK\Flash\MT6592__Xiaomi__HM_NOT E_1W__lcsh92_wet_jb9__4.4.2__ALPS.KK1.MP1.V2.46\ All done! Done! Elapsed: 00:04:48 Reconnect Power/Cable! Finish at : [12/29/2015 / 10:30:02 PM] |
The Following User Says Thank You to mawan161080 For This Useful Post: |
