08-17-2020, 18:02 | #1 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Bolivia
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | xiaomi mtk I have a question and doubt about xiaomi mtk for example redmi 6, 6a, note 8 pro, mi play. I understand that when find device is ON it asks for authorized Xiaomi account. but they can be flashed with infinity, if my find device is OFF without the need for xiaomi account? or if I have xiaomi dead that only vibrates, but is find device OFF and with the bootloader unlocked, can it be flashed to revive dead cell phones that only vibrate? |
08-18-2020, 06:40 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MTK in BROM mode will ask auth in any case. Not matter, even unlocked BL or not. MTK in Preloader mode will work in ON or OFF state, other depend on model, e.g. some have open preloader, some not ( RM8Pro as example ) and require unlock bl + install open preloader. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
08-18-2020, 14:53 | #3 (permalink) |
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | thanks for answering sir I have Redmi 6 cereus, with unlocked bootloader and OFF state I tried to put eng rom via fastboot to repair the imei with eft, but some files did not write to it correctly. here the flashing logo via fastboot: EFT Dongle Connecting Fastboot ....... Connecting Fastboot .......Ok FLASHING FIRMWARE TO PHONE..... Flashing flash tools"...........OK Flashing c: "^product: *cereus"...........OK Flashing c: "^product: *cereus"...........OK Flashing crclist.txt" ...........OK Flashing sparsecrclist.txt" ...........OK Flashing preloader_cereus.bin" ......... Flashing preloader_cereus.bin" ........Fail Flashing logo.bin" ...........OK Flashing tee.img" ...........OK Flashing scp.img" ...........OK Flashing sspm.img" ...........OK Flashing lk.img" ......... Flashing lk.img" ........Fail Flashing tee.img" ...........OK Flashing scp.img" ...........OK Flashing sspm.img" ...........OK Flashing lk.img" ......... Flashing lk.img" ........Fail Flashing odmdtbo.img" ...........OK Flashing spmfw.img" ...........OK Flashing md1img.img" ...........OK Flashing vendor.img" ...........OK Flashing system.img" ...........OK Flashing cache.img" ...........OK Flashing recovery.img" ...........OK Flashing boot.img" ...........OK Flashing cust.img" ...........OK Flashing vbmeta.img" ...........OK Flashing userdata.img" ...........OK Flashing exit 0...........OK Flashing : error...........OK Flashing B 1...........OK Flash Done By EFT Dongle after finishing the process redmi 6 only vibrates Operation : Identify [ v2.14 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+ARB BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2012 | Manual : Enabled BROM : SOCID : FA6A2CC37908BDD34C365AD2D2D9B19BAEE74451DB4AFACAF6 D66618E82E6600 BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SLA BROM : SLA Passed! BROM : SLA CHALLENGE required! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
