08-05-2020, 20:02 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Software write exactly - you trying DOWNGRADE device! Flash newer firmware version. |
08-05-2020, 20:15 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Atleast post your identify log first. Then check support/google for similar or newer sw version info. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
08-06-2020, 18:20 | #5 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Algerie B.S Age: 46
Member: 76754 Status: Offline Sonork: 1580514 Thanks Meter: 37 | i know support and google. last version not found in your s support and find "ozip" in google if you have get me link? Code: Operation : Write Flash [ v2.11 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Disabled Verify HW/SW : Disabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :22 [FL] : Set : preloader_oppo6771_17331.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : spmfw.img [FL] : Set : tinysys-scp.bin [FL] : Set : tinysys-scp.bin [FL] : Set : tinysys-sspm.bin [FL] : Set : tinysys-sspm.bin [FL] : Set : cam_vpu1.img [FL] : Set : cam_vpu2.img [FL] : Set : cam_vpu3.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : odmdtbo.img [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : odm.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x11E7DEA7C [ 4,48 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM18) MODE : BOOTROM PORT : 18 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F7 | Manual : Disabled BROM : SOCID : 661C0FA8336267310ECD4E8E0B0A82504871A9E28C92DBB8E02EA8533DD5D7F0 BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_BR_HIGH.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6771_17331.bin EMI : CNT : 000E EMI : [00] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4,00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4,00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6,00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6,00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4,00 GB ] EMI : [09] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4,00 GB ] EMI : [0A] : eMMC : LP_DDR4X : ID : 90014A684445615033 : VEN : HYNIX | DEV : hDEaP3 : RAM : [ 6,00 GB ] EMI : [0B] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ] EMI : [0C] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4,00 GB ] EMI : [0D] : eMMC : LP_DDR4X : ID : 13014E53304A394438 : VEN : MICRON | DEV : S0J9D8 : RAM : [ 4,00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] EMMC: 90014A484347386134A40A5A712C1559 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : DB27A51755FBBF6E2A208B1D81C560AE DA : USB : HIGH-SPEED Boot done! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER ERR : 0xC002002D ERR : SEC : VIOLATE ANTI ROLLBACK ERR : 0x00000000|0x000421BC Error : Flashing failed! >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! |
