04-18-2009, 16:06 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Algeria
Member: 158242 Status: Offline Sonork: 100.1591384 Thanks Meter: 194 | Sfr 111 ok Périphérique: SFR-111 Ready ==== log: [18/04/2009 15:59:45] ==== COM11 [VCP0] selected module v1.63 Périphérique: SFR-111 Contrôle des données, attendre ... Operation: déverrouiller unlock method-1 Boot ... loader: standard type: 4 Appuyez et restez appuiez sur le bouton "Power" dès maintenant! loading... next part... boot answer: 01 lachez bouton d'alimentation maintenant! Boot Done Ensemble bauds ... 115200 Ensemble bauds Done Connecting ... Flash 00EC:257E Connecting Done Check hardware ... sw version: SFR-P108A2FMV1.0.0B03 04.12.00 18.26.11 08.02.00 Aug 28 2008 SFR Check hardware Done Check parameters ... Check parameters Done backup critical area ... lecture eeprom-static... fichier sauvegardé: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-static_20090418-160004.B1E.bin loading data... data loaded lecture eeprom-security... fichier sauvegardé: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-security_20090418-160005.B1E.bin lecture eeprom-complete... fichier sauvegardé: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-complete_20090418-160012.B1E.bin reading additional data... fichier sauvegardé: C:\Program Files\InfinityBox\Pana01\SFR-111_lock-area_20090418-160025.B1E.bin backup critical area Done Check memory ... lock found Check memory Done écrire ... Erasing: lock-area Writing: lock-area écrire Done Terminé, temps utilisé: 54 sec Retirez / remettre la batterie maintenant! |
The Following User Says Thank You to djlicks For This Useful Post: |
04-18-2009, 19:48 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
06-01-2009, 15:32 | #3 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Tunisia my love Age: 43
Member: 304362 Status: Offline Thanks Meter: 347 | for me not unlocked ------------------------------------ COM13 [VCP0] selected Device: Avvio-103A Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 00EC:257E Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Avvio-103A_eeprom-sta_20090303-151718.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Avvio-103A_eeprom-sec_20090303-151720.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Avvio-103A_eeprom-complete_20090303-151722.B1E.bin reading additional data... done backup critical area Done Check memory... error: unknown firmware, read flash and send to support ! Check memory Failed Finished, Remove/Install battery now ! Time used: 18 sec |
06-01-2009, 15:33 | #4 (permalink) |
06-01-2009, 22:06 | #5 (permalink) | |
You need to select correct model before press "sp-unlock" button. | |
ZTE SFR 111 unlock done by infinity | BouRRi_GSM | Infinity-Box | 3 | 03-13-2015 18:06 |
sfr 111 noir unlock ok | dindou78 | SAGEM JTAG UNLOCKER | 6 | 09-04-2014 14:25 |
pls pinout sfr 231 and sfr 111 | ouassini | SMTi | 8 | 05-30-2010 20:09 |
21/10/2008 Microbox always first in the world New ZTE SFR 111 ADDED FOR FEEEEEEEEEEEE | hitibiti | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 33 | 08-03-2009 22:16 |
02 Nov 2008: LG-KP135, SFR-111, Bird-V5518+, ZTE-A136, Zong-A136 models supported | InfinitySupport | Infinity-Box | 36 | 06-21-2009 10:59 |
