03-16-2018, 06:40 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: .........
Member: 665025 Status: Offline Thanks Meter: 44 | cherry mobile flare j3 lite dead,. pls help,... Card found : S/N : Chinese Miracle II [MTK module] v 1.58 Operation : Flash Erase [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 41 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Flash Erase [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 41 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6580 , Project : t960w_v1_w_frog_m05c_h1240_fw , Storage : EMMC Files found : 10 , Set to Flash : 9 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 41 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! pls help to revive team,.. |
The Following User Says Thank You to markrempillo For This Useful Post: |
03-16-2018, 07:21 | #2 (permalink) |
Freak Poster Join Date: Jan 2017
Member: 2671513 Status: Offline Thanks Meter: 121 | https://www.needrom.com/download/cherry-flare-j3-lite/ ROM Phone Cherry Flare J3 Lite – ROM Android 7.0 ONLY MT6580 Update Official Cherry Flare J3 Lite version: Cherry_H1240_PH_FlareJ3Lite_10282017_V1.9 – full_t960w_v1_w_frog_m05c_h1240_fw-user 7.0 NRD90M —————————————————————————————————————————————————— ————– Official Cherry Flare J3 Lite version: Cherry_H1240_PH_FlareJ3Lite_09182017_V1.7 – full_t960w_v1_w_frog_m05c_h1240_fw-user 7.0 NRD90M Gapps include – No Rooted Language support: Multilang |
The Following 2 Users Say Thank You to dadarko For This Useful Post: |
03-16-2018, 08:48 | #3 (permalink) |
Member: 665025 Status: Offline Thanks Meter: 44 | i have 2 downloaded firmware with same as that at needrom,. the problem is how to flash back the preloader and also the whole firmware,.. |
03-16-2018, 09:51 | #4 (permalink) |
No Life Poster Join Date: Dec 2015 Location: Somewhere on the Internet
Member: 2500215 Status: Offline Thanks Meter: 417 | How do you flash before? If preloader only, Then do Init Preloader from Exta |
The Following 2 Users Say Thank You to Southsider2009 For This Useful Post: |
03-16-2018, 10:37 | #5 (permalink) | |
Member: 665025 Status: Offline Thanks Meter: 44 | Quote:
before i flash it with multiloader, after erase, i think some percent on writing stop,.. when i check my device, it doesnt boot,. only mtk port detected on device manager,. | |
