05-02-2016, 17:32 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Ethiopia
Member: 449991 Status: Offline Thanks Meter: 933 | Y541-u02 boot faild help acording to manual i select Huawei_Y541_Y5C.sldr on pac flash tab on sp sc77xx but always faild what i miss help SLDR Load Ok BB CPU : SC7731 Huawei Y541-U02 (Y5C) For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : Check/Read Info [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 196 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
05-02-2016, 17:39 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Probably - you have some drivers problem. Check them. Phone reboot once during booting. If you need reset/format fs - tick SVC and do format. Security also can be repaired in SVC mode. |
07-05-2016, 14:17 | #3 (permalink) |
Freak Poster Join Date: May 2006 Location: A
Member: 272591 Status: Offline Sonork: 100.1579461 Thanks Meter: 45 | Code: Operation : SP Unlock [ v1.19 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Checking Structure ... SimLock state : Not Locked! Nothing to do! Elapsed: 00:00:15 Reconnect Power/Cable! |
07-05-2016, 15:00 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Because they not locked. Huawei made strange customizations features, which are depend on SW version inside phone. Just try different SW version, probably, some of them will work with your network providers. |
