Y541-U2 Emergency Calls Only After Unlock The phone is GLOBE Ph locked and now, can't even use the original SIM. Anyone of you with working NV, please share. |
Hello. IMEI inside is Ok now? BaseBand state? Normally, for those phones, enough PAC flashing for unlock/repair. |
IMEI: Ok And I tried to reflash with: Y541-U02V100R001C567B105 |
Try reflash with factory flasher also. CM2 by default not flash factory nvm for avoid calibration and etc damage. |
Possible change IMEI, in the philippines Globe and Smart are Blocking IMEI if there customer will not pay, including those MODEMS, ultera |
Loose signal? Or not seen it at all? What if you try read NVM from another one same phone and write to it, make factory resetand check? |
