y625-u51 unbrick firmware Needed I have Y625-U51 stuck in Qualcomm 9008 mode Please, Anyone, have firmware backup from CM2QLM upload it for me And I will be thankful because device is dead now :( |
You find it bro? i need it! |
No one can share this firmware !? Sent from my Nexus 5X using Tapatalk |
Here readed by Infinity QLM MSM8610__HUAWEI__HUAWEI__ANDR_v4.4.2__HUAWEI_Y625-U51__HWY625-U__Y625-U51 |
Thanks, Bro but I have an error in flashing http://i68.tinypic.com/2eov12w.png whats the meaning of this? |
Im have no idea, firmware is loaded from fully 100% working phone. |
I know that is my bad luck :( but thanks for sharing this firmware anyway :D |
Check memory, run all test's to see if not damaged or read only. |
Many Thanks to thedgd ! Flash done , phone alive again ! Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.11 Operation : Identify [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 09D75539 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 4EB62C2A85111E09F6ABA5AA75CC4484 ID_BLOCK_L : B2C14FDED342EC799C5B3CF5FF36202B Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : ORINOQUIA ProdName : Y625-U03 ProdModel : Kavak Y625-U03 Device : KVY625-U AndroidVer: 4.4.2 Manufact. : HUAWEI QLMxCPU : MSM8610 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : HUAWEI Device Manufact.: HUAWEI Device Model : HWY625-U Device CPU : MSM8610 Device IntName : Y625-U51 Device Version : 4.4.2 CU_SWVer : HUAWEI Device Compile : 14.9.2015 ?. 08:17:24 Device ExtInfo : HUAWEI Y625-U51 Load Ok! Operation : Flash [ v1.11 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 09D75539 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 4EB62C2A85111E09F6ABA5AA75CC4484 ID_BLOCK_L : B2C14FDED342EC799C5B3CF5FF36202B Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Files in Chain : 17 Flashing now Flashing : gpt_main0.bin Flashing : sbl1.mbn Flashing : deploy.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : misc.img Flashing : NON-HLOS.bin Flashing : boot.img Flashing : system.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : lsplash.img Flashing : userdata.img Flashing : gpt_backup0.bin Boot settings configured! Flashing done! Done! Elapsed: 00:03:11 Reconnect Power/Cable! |
Can you please reupload? link is dead |
here is new link https://mega.nz/#!q04kyZTS!KS02aZ7Gu...FPb46MKbW6usCk |
i try to flash this firmware bro but stuck at userdata.img! any solution plz |
i try to flash this firmware bro but stuck at userdata.img! |
You MAY have luck or MAY NOT have regarding fixing them. - Reason #1: It has nothing to do with CM2 or Flash file - Reason #2: Low quality eMMC (Flash Memory) was used for those models, which "wear out" after some year(s), and most used parts (like part for userdata/user storage area), gets corrupted at physical level (similar like Hard Disk Drive). So, to fix such errors - replacing flash memory is the only cure. That is NOT software repair, but hardware, and needs some skills to do it. (together with ability to find brand new compatible or same eMMC chip). I have personally seen a lot same case Huawei phones, many different models, and only 20-30% was possible to fix permanently. Just a simple experience sharing, to save you from wasting time with such phones. Have a nice day b.r. Alex |
