03-19-2017, 14:22 | #1 (permalink) |
Freak Poster Join Date: Feb 2010 Location: Tunisia Age: 36
Member: 1229369 Status: Offline Thanks Meter: 56 | your own backup is a bad file?????? NOW the strange problem.. Load File Bad file detected! try again... Load File Bad file detected! the *******r is not happy at all.. me too.. searching for the flash file no luck.. please help me sorry for the english Last edited by majdibenelwaere; 03-19-2017 at 14:30. |
03-19-2017, 14:31 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, the bad file come only for nand as Nand writing Not supported,, but ur telling u do Smart Av,,, If it is Nand then Smart AV not support for nand plz post Read logs so tht team can give u a better answer |
The Following User Says Thank You to princesaddam For This Useful Post: |
03-19-2017, 14:32 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Did you hear about logs? BTW - before work with SW you must have som e knowledge and skills. Atleast basic one. I see there is no any of them at all. |
03-19-2017, 14:47 | #4 (permalink) |
Member: 1229369 Status: Offline Thanks Meter: 56 | Operation : Read Flash [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3758564D4201CA8BC6047193 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201CA8BC6047193 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x406713B0CE5638B45883F60459A0C8F3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Read Ok , collect info Brand : MAC ProdName : A215_MULA_4G ProdModel : A215_MULA_4G Device : A215_MULA_4G AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : ALPS.KK1.MP1.V2.10 Saved to : D:\g900 read\MT6592__MAC__A215_MULA_4G__ALPS.KK1.MP1.V2.10 __Android_4.4.2.ispff Done! Elapsed: 00:29:07 Reconnect Power/Cable! |
03-19-2017, 14:47 | #5 (permalink) |
Member: 1229369 Status: Offline Thanks Meter: 56 | Operation : Remove Viruses [SmartAV] [ v1.56 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3758564D4201CA8BC6047193 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201CA8BC6047193 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x406713B0CE5638B45883F60459A0C8F3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 35 Removing infected files and scripts ... SmartAV Report : Removed 35 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! Done! Done! Elapsed: 00:01:55 |
03-19-2017, 14:52 | #7 (permalink) |
Member: 1229369 Status: Offline Thanks Meter: 56 | dont tell me about skills... i do everything right.. make backup.. try your software to remove virus.. no luck then i have to write back th flash file.. maybe not supported for smartAV but i guess i can read and write buckup without prob, no?? |
03-19-2017, 15:43 | #8 (permalink) |
Freak Poster Join Date: Dec 2011 Location: rajasthan,india
Member: 1705399 Status: Offline Thanks Meter: 81 | dear friend dear friend you can flash this backup file with sp flash tool also and if after flashing its same hang on logo then do repair user data catche with cm2 t mtk, its 100% working solution for your problem. |
The Following User Says Thank You to jitendra 1980 For This Useful Post: |
03-19-2017, 16:05 | #9 (permalink) |
Member: 1229369 Status: Offline Thanks Meter: 56 | not really the backup is *ispff can not write it with any other tool... anyway thnks for reply i solve the prob by finding the correct flash file.. thank you @jitendra1980 |
03-19-2017, 16:15 | #10 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | FLASH dumps used by cave mans, nowdays all peoples uses FILES. FLASH FILES. NOT DUMPS. All peoples reading manuals ( they are on support ) before make things, which they not know. So, you have proved you near zero level. |
03-19-2017, 16:25 | #11 (permalink) |
Member: 1229369 Status: Offline Thanks Meter: 56 | then you steal cave mans money... i think i found read full botton on your software.. and i used your exclusive dump file with your special extension... i think zero level because i m using your software.. i will be polite and leave now.. cave mans near zero level.. no good words from man who i must trust him or his work |
03-19-2017, 16:30 | #12 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Again proove of complete non-understand of how all works. If you even try select mode to SP and then select file - it start working Anyway - improve skill and learn. Atleast manuals and forum. It will help you in future well. |
03-19-2017, 16:53 | #15 (permalink) |
Member: 1229369 Status: Offline Thanks Meter: 56 | hhhhh and this prove your level... MTK module damage my phone by ''very high level smartAV''.. can not accept his own dump (this is very stupid as some how can not read his handwritnig) i found the correct flash file.. use FREE spflash tool and VOILA.. resume: i use paid soft to damage phone. i use FREE one to fix it.. realy im near zero level for using this box. can anyone close this thread? thanks for anyone trying to help me.. even who said that know everything but really he is nothing. |
