Old 03-19-2017, 14:22   #1 (permalink)
majdibenelwaere's Avatar
Member: 1229369
Thanks Meter: 56
your own backup is a bad file??????
it s not happened for the first time... i have a clone g900 with virus problem.. as always before doing anything i read backup.. it took 30 minutes. ok no problem.. after using '' smart AV'' (as you said) phone hang on logo.. i said it s ok i have a buckup...
NOW the strange problem..
Load File
Bad file detected!
try again...
Load File
Bad file detected!
the *******r is not happy at all.. me too..
searching for the flash file no luck..
please help me
sorry for the english
Old 03-19-2017, 14:31   #2 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hello,
the bad file come only for nand as Nand writing Not supported,, but ur telling u do Smart Av,,, If it is Nand then Smart AV not support for nand plz post Read logs so tht team can give u a better answer
The Following User Says Thank You to princesaddam For This Useful Post:
Old 03-19-2017, 14:32   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Did you hear about logs?
BTW - before work with SW you must have som e knowledge and skills. Atleast basic one. I see there is no any of them at all.
Old 03-19-2017, 14:47   #4 (permalink)
Member: 1229369
Thanks Meter: 56
Operation : Read Flash [ v1.56 ]
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BB_CPU_NME : [MediaTek] MT6592_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8A
NAND Flash : NOT INSTALLED
eMMC Flash : 1501004B3758564D4201CA8BC6047193
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMVX7
[eMMC] : FLASH_CID : 1501004B3758564D4201CA8BC6047193
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x406713B0CE5638B45883F60459A0C8F3
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
Read Ok , collect info
Brand : MAC
ProdName : A215_MULA_4G
ProdModel : A215_MULA_4G
Device : A215_MULA_4G
AndroidVer: 4.4.2
MTKxCPU : MT6592
MTKxPRJ : ALPS.KK1.MP1.V2.10
Saved to : D:\g900 read\MT6592__MAC__A215_MULA_4G__ALPS.KK1.MP1.V2.10 __Android_4.4.2.ispff
Done!
Elapsed: 00:29:07
Reconnect Power/Cable!
Old 03-19-2017, 14:47   #5 (permalink)
Member: 1229369
Thanks Meter: 56
Operation : Remove Viruses [SmartAV] [ v1.56 ]
SmartAV Conf : 100/80/2000
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scanning FileSystem now , please wait
Scan Done, infected files found : 35
Removing infected files and scripts ...
SmartAV Report : Removed 35 infected files!
Making additional operations ...
Special Op #1 : Clear Recovery Data Ok!
Special Op #2 : Clear UserData Ok!
Special Op #3 : PostFix Ok!
Done!
Done!
Elapsed: 00:01:55
Old 03-19-2017, 14:48   #6 (permalink)
Member: 1229369
Thanks Meter: 56
trying to flash backup
Load File
Bad file detected!
Load File
Bad file detected!
Load File
Bad file detected!
Old 03-19-2017, 14:52   #7 (permalink)
Member: 1229369
Thanks Meter: 56
dont tell me about skills... i do everything right.. make backup.. try your software to remove virus.. no luck then i have to write back th flash file..
maybe not supported for smartAV but i guess i can read and write buckup without prob, no??
Old 03-19-2017, 15:43   #8 (permalink)
Member: 1705399
Thanks Meter: 81
dear friend
dear friend you can flash this backup file with sp flash tool also and if after flashing its same hang on logo then do repair user data catche with cm2 t
mtk, its 100% working solution for your problem.
The Following User Says Thank You to jitendra 1980 For This Useful Post:
Old 03-19-2017, 16:05   #9 (permalink)
Member: 1229369
Thanks Meter: 56
not really the backup is *ispff can not write it with any other tool... anyway thnks for reply i solve the prob by finding the correct flash file.. thank you @jitendra1980
Old 03-19-2017, 16:15   #10 (permalink)
JayDi's Avatar
Member: 462970
FLASH dumps used by cave mans, nowdays all peoples uses FILES. FLASH FILES. NOT DUMPS.
All peoples reading manuals ( they are on support ) before make things, which they not know. So, you have proved you near zero level.
Old 03-19-2017, 16:25   #11 (permalink)
Member: 1229369
Thanks Meter: 56
then you steal cave mans money... i think i found read full botton on your software.. and i used your exclusive dump file with your special extension... i think zero level because i m using your software.. i will be polite and leave now..
cave mans
near zero level..
no good words from man who i must trust him or his work
Old 03-19-2017, 16:30   #12 (permalink)
JayDi's Avatar
Member: 462970
Again proove of complete non-understand of how all works.
If you even try select mode to SP and then select file - it start working
Anyway - improve skill and learn. Atleast manuals and forum. It will help you in future well.
Old 03-19-2017, 16:33   #13 (permalink)
Member: 1229369
Thanks Meter: 56
prooved by saving phone damaged by your ''skilly software''
Old 03-19-2017, 16:38   #14 (permalink)
JayDi's Avatar
Member: 462970
Seems as stupidly is your second name
Bye.
Old 03-19-2017, 16:53   #15 (permalink)
Member: 1229369
Thanks Meter: 56
hhhhh and this prove your level...
MTK module damage my phone by ''very high level smartAV''.. can not accept his own dump (this is very stupid as some how can not read his handwritnig)
i found the correct flash file.. use FREE spflash tool and VOILA..
resume:
i use paid soft to damage phone.
i use FREE one to fix it..
realy im near zero level for using this box.
can anyone close this thread?
thanks for anyone trying to help me.. even who said that know everything but really he is nothing.
Page generated in 0.25202 seconds with 8 queries
