03-16-2017, 14:27 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 608516 Status: Offline Sonork: 100.1607007 Thanks Meter: 123 | yu5010 fLashing failed help team Operation : Flash [ v1.11 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0C45AD3D ID_BLOCK_I : 007050E1 ID_BLOCK_L : C8B56C20B1E17AEC92322FFFE0A7B93F ID_BLOCK_L : EA9EBDD833B37A768F1276DC48A5D7B4 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 153 Flashing now Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : splash.img Flashing : sec.dat Flashing : aboot.bin ProgStart : start 396384, num 2048 Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Operation : Reset Settings [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0C45AD3D ID_BLOCK_I : 007050E1 ID_BLOCK_L : C8B56C20B1E17AEC92322FFFE0A7B93F ID_BLOCK_L : EA9EBDD833B37A768F1276DC48A5D7B4 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format failed! Remove FRP Additional data remove failed! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
