12-29-2009, 05:30 | #1 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | z96 can not power on tryed everything Quote:
thanks | |
12-29-2009, 21:34 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! next step is flashing by this file: flashfiles/ChineseMiracle/_MT6226/Z96M_M1_PCB01_GPRS_MT6226_S01.MAUI_08A_W08_36_MP_V 7_MP_F2_16m_En_Fr_Es_Tr_Farsi_Pt_Ar.B0M.bin |
12-29-2009, 22:44 | #3 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
Code: COM3 [VCP0] selected module v3.03 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Z96M_M1_PCB01_GPRS_MT6226_S01.MAUI_08A_W08_36_MP_V7_MP_F2_16m_En_Fr_Es_Tr_Farsi_Pt_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:DD55:7743 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.CDBC0A96.[Z96M_M1_PCB01_GPRS_MT6226_S01.MAUI_08A_W08_36_MP_V7_MP_F2.BIN_9F54B685].rpl rom info detection finished device-id: CDBC0A96 rom info ver: 05 sw version: Z96M_M1_PCB01_GPRS_MT6226_S01.MAUI_08A_W08_36_MP_V7_MP_F2.BIN project-id: MAUI.08A.W08.36.MP.V7.MP.F2, 85B6549F code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Z96M_M1_PCB01_GPRS_MT6226_S01.MAUI_08A_W08_36_MP_V7_MP_F2__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\Z96M_M1_PCB01_GPRS_MT6226_S01.MAUI_08A_W08_36_MP_V7_MP_F2__ffs_20091230-104142.B0E.bin flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\Z96M_M1_PCB01_GPRS_MT6226_S01.MAUI_08A_W08_36_MP_V7_MP_F2__system_log_CDBC0A96_9F54B685_20091230-104153.B0X.bin Area: Firmware flash: 98000300000001:2BEA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\Z96M_M1_PCB01_GPRS_MT6226_S01.MAUI_08A_W08_36_MP_V7_MP_F2__system_log_CDBC0A96_9F54B685_20091230-104208.B0X.bin Finished, time used: 2 min 1 sec Remove/Install battery now ! | |
T610 can flash but can not power on | hooi76 | Sony Ericsson Hardware Repair | 0 | 03-23-2008 02:57 |
1100 Rh-18 Can Flashing But Can Not Power On | DeltaGSM | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 07-12-2004 21:33 |
HELP! LG7100 can not power on after running the photo loader. | southriver | LG | 0 | 12-27-2003 16:32 |
8310 can not power on when put batt | watch man | Nokia Hardware & Hardware Repair | 6 | 12-09-2002 02:36 |
Alcatel OT3XX can not power ON | hooi76 | Alcatel TCL Hardware Repair | 5 | 12-26-2001 19:58 |
