zonda 1075 unlock fail Support: I test again 2 Zonda 1075 and unlock fail. Still locked in alls the methods. The MModule 2.32 need fix this. Please fix unlock process.... Regards |
COM3 [VCP1] selected Device: Zonda-1075 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:316C:8A67 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SL399_ZONDA_PCB01_GPRS_MT6226_S01.SL399.06A.W06.36 .MP.V36.F2.BIN ver. sw2: SL399.06A.W06.36.MP.V36.F2, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[SL399_ZONDA_PCB01_GPRS_MT6226_S01.SL399.06A.W06.36 .MP.V36.F2.BIN]... file saved: C:\Archivos de programa\InfinityBox\MModule\eeprom[SL399_ZONDA_PCB01_GPRS_MT6226_S01.SL399.06A.W06.36 .MP.V36.F2.BIN]_20080912-145153.B0E.bin flash: B0001D00000000:B0001D00000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... buffer management operation in progress... buffer management operation failed error: probably unknown firmware version, read flash and send to support: [email protected] Special operation Done Write... flash: B0001D00000000:B0001D00000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 63 sec Remove/Install battery now ! COM3 [VCP1] selected Action: unlock unlock method: smart fast Model: Zonda-1075 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:316C:8A67 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SL399.06A.W06.36.MP.V36.F2 Version: EZIO27_06A_HW 42 byte(s) read imei: 35568401111418 connection Ok 145 byte(s) read reading data... building new data... writing data... done Finished, time used: 15 sec Remove/Install battery now ! |
Hello, Can you sell to us this phone for detailed tests ? We will pay for phone + delivery. |
