07-24-2007, 10:33 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: PakLink.org
Member: 71321 Status: Offline Sonork: 100.1576579 Thanks Meter: 428 | ZT 588 pin out need conector is 12 pin mini ___________________________ / 1 2 3 4 5 6 7 8 9 10 11 12\ ----------------------------- pin 1,2 charger volt pin 12 is ground i try will all pin but can't find out pin also see on PCB but can't |
09-15-2007, 09:23 | #5 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | hi i need the pinout for zt 588 and it has 1......12 pin and the second pin is ground, pls help me to find the pinout |
09-22-2007, 20:00 | #6 (permalink) |
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | I m requesting again for the pinout of zt588 , its as like as nokia 6300 , pin type 1.....12 and the port is like samsung d800. its second pin is ground, pls help to identify the pinout . |
09-23-2007, 07:23 | #7 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Dont Worry Brother Just Open The Phone And You Will Find Rx Tx Gnd On Pcb And Enjoy Br Maple Gsm |
The Following User Says Thank You to maplegsm For This Useful Post: |
09-23-2007, 09:01 | #9 (permalink) | |
Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 | |
09-23-2007, 12:35 | #10 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Here is this picture....posted alot of times....And this phone also have the tx rx points on the pcb under camera speakers and buzzer.... BR MUNEEB AKHTAR RAZA |
09-24-2007, 21:28 | #11 (permalink) |
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | same but ... but the zt588 6300 is not same as that pinout, its second pin is gnd . i have 3 pcs of that set still now ... |
Ztc 588 pin out | lallyviji | Chinese Models & Cloned Phones | 0 | 05-06-2009 04:16 |
SX1_USB pin out needed??? | uni_gsm_tech | E-Gold Based Phones | 1 | 07-10-2004 20:46 |
N100 pin-out need!!! Please!!! | Szinyo | VLSI, Conexant, Skyworks and Old Models | 0 | 01-23-2002 23:38 |
V66a pin-out need | spear-gsmhacking | Motorola P2k | 0 | 09-03-2001 01:13 |
c30 100% wotking pin-outs , need working softW .. | makona | NON Siemens Brand (ODM Phones) | 0 | 04-08-2001 08:08 |
