zt168 pinout please helloi need zt168 pinout urgently ! zt168 with 1*12 pin connector . |
any body help ? i need this pinout on the board |
hello! i can advice how to find pinout by multimeter, if you dont have pinfinder. but first you have to check if this phone is based on MT62xx MCU. you can do this by typing *#0044# and push green(send) button. if language will reset to English - we can continue |
yes , its reset to english plz continue |
hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
