ZT321 Pinout Anybody have working pin-out for this model??? thanks and regards... |
man, better ask here http:///vbb/forumdisplay.php?f=425 because special forum for Infinity-Box Chinese Miracle exist... |
Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
please give us pinout for ZT321 |
is it a Bluetooth Phone...................... 6-Tx 7-GNd 8-Rx try this |
7 is not ground sir any other pinout for zt321? |
hello! maybe it worth to post your GND pin location to avoid guessing your pinout? |
12pins 8 is ground..... |
me need pinout for this phone zt321..............hope anyone can post picture where is the tx rx and ground.....chinese phone real problem with pinout..........also i have zt 500 but no one can give pinout....................... |
hello! if nobody can help with pinout, but phone is MT 62... procesor based- i would advice to use simple method to find needed pins which require only having multimeter: http:///vbb/attach...7&d=1187384324 we will release very soon new box_add_on which will find pinout automaticly. will try to keep it costs for existing users as minimum as possible |
