ztc A898 i need pin out n flash file hiiii i need pin outs n flash file for ztc a898 |
Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
thnx 2 aashir n infinity team hiiiiiii thnx dear aashir dat pin outs r working thnx ones again dear keep it up .....................:) |
i have same set problem is set dead when i m attach with infinity softwaare says new finware detected send to the support but i m need new flash fuile for live this set again backup_flash[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL_L5 SM_204_070918_LD-TR0_OV0_SS |
hello tarunvishal! first send you flash backup to us. we will check it. also: did you try to make complete format? |
Hi , I got new Ztc A898 mobile . There option of mobile view is not working. Also i couldnt connect to GPRS even through service operator sent the details . |
hello! you can try safe backup- maybe it will help you. all other operation only after you make full backup |
