04-18-2008, 17:05 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | ztc k700 no format i found rx tx manually tx-3 rx-7 gnd-11 but this log show pin type connector_2x6_mini COM4 [VCP1] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 98 sec Remove/Install battery now ! i try power button long time press mobile is on & same problem restart without sim |
04-19-2008, 07:36 | #3 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | complete formate COM4 [VCP1] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot disabled high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd PL064J D 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd PL064J D 8Mb detecting chip #02 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd PL064J D 8Mb detecting chip #03 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd PL064J D 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... slowest Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd PL064J D 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd PL064J D 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN ver. sw2: MAUI.06B.W07.20.MP.V7, 00000000 ffs offset/size: 003C0000/00040000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 003C0000 flash: 01227E22022201:18E59F00000000 checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 003C0000 detecting eeprom/ffs size... eeprom/ffs size: 00440000 ffs chip: 00 eeprom/ffs area: 00000000:003C0000-007FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 01227E22022201:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22022201:18E59F00000000 Finalization Done Finished, time used: 58 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! but same problem |
04-19-2008, 11:00 | #5 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | ztc k700 ok COM4 [VCP1] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1041:3E00 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.05C.W06.16 Version: MALATA26_05C_HW detecting structure #2... done 60 byte(s) read imei: 35510801012597 connection Ok building list... done items total: 207 i found tx-5 rx-9 gnd-11 mobile 100% working |
07-15-2008, 18:28 | #6 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | Pinout Ztc K700 100 % Working -------------------------------------------------------------------------------- COM4 [VCP1] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1041:3E00 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.05C.W06.16 Version: MALATA26_05C_HW detecting structure #2... done 60 byte(s) read imei: 35510801******* connection Ok building list... done |
k700 no charging indication i will remove ic make a jumper no workplease help me | prakash40 | Sony Ericsson Hardware Repair | 0 | 09-29-2009 07:44 |
k700 no charging indication i will remove ic make a jumper no workplease help me | prakash40 | Sony Ericsson Hardware Repair | 0 | 09-26-2009 06:33 |
ZTC N82 can't format | bachirDraria | Infinity-Box | 21 | 07-15-2008 20:40 |
ztc 268 ok formating infinity | aleem26 | Chinese Models & Cloned Phones | 1 | 06-30-2008 19:14 |
ZTC 8188 succesfuly format | maheshsaiganesh | Infinity-Box | 1 | 04-25-2008 08:35 |
