10-02-2007, 20:54 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,537 | hello! unfortunatly we dont have pinout for this phone in our database. you can try to find pinout by yourself or maybe some of our forum member will help you |
10-03-2007, 08:37 | #5 (permalink) |
Junior Member Join Date: Mar 2007
Member: 469015 Status: Offline Thanks Meter: 1 | hello! unfortunatly we dont have pinout for this phone in our database. you can try to find pinout by yourself or maybe some of our forum member will help you ----------------- OK! Thanks! |
10-04-2007, 00:29 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
10-07-2007, 11:16 | #7 (permalink) |
Member: 469015 Status: Offline Thanks Meter: 1 | How to flash ZT-199: 1.Disassemble the phone. 2.Disconnect SkyWorks module under keyboard (Necessarily). 3.Connect RX,TX,GND (view attach) 4.Flash on any boot and flash speed. Sorry for my English! |
The Following User Says Thank You to n3gr0 For This Useful Post: |
10-26-2007, 20:50 | #13 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | here is pic when skyworks module is removed A203 well supported by infinity |
The Following User Says Thank You to BouRRi_GSM For This Useful Post: |
11-19-2007, 18:17 | #14 (permalink) |
Freak Poster Join Date: Jan 2005 Location: thailand Age: 44
Member: 106455 Status: Offline Sonork: not have Thanks Meter: 3 | Yes , is work True When i remove skywork pcb I can read, format ,and flash is easy Last edited by InfinitySupport; 11-19-2007 at 19:10. Reason: attachment removed |
ZT-6618 need pinout | farhanali | Infinity-Box | 4 | 09-30-2008 20:41 |
Ztc X668 I Need Pinouts N E One Can Help Me | ikkks | Infinity-Box | 3 | 08-11-2008 19:42 |
ZTC zt af 320 pinouts | sekharv | Infinity-Box | 1 | 04-11-2008 11:28 |
ZTC ZT-199 Diamond.Help | romarrio | Infinity-Box | 1 | 02-10-2008 00:22 |
ZTC ZT-199 need pinout help me | farhanali | Infinity-Box | 9 | 11-12-2007 07:26 |
