Old 11-26-2008, 05:15   #1 (permalink)
arabie's Avatar
Member: 699870
Sonork: 100.1647674
Thanks Meter: 69
infinity team pls help
i have vodafone ZTE 125 itry to unlock this phone some error pls wat will i do? help me team
heres a log
module v1.54
Device: ZTE-125
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-sta...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sta_20081125-192450.B1E.bin
loading data...
data loaded
reading eeprom-sec...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sec_20081125-192453.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20081125-192500.B1E.bin
reading additional data...
done
backup critical area Done
Check memory ...
current status: #2, already unlocked
already done (mode-0), operation aborted
Check memory Failed
Finished, time used: 32 sec
Remove/Install battery now !
Old 11-26-2008, 05:40   #2 (permalink)
arabie's Avatar
Member: 699870
Sonork: 100.1647674
Thanks Meter: 69
were sleeping,, but any thanks the phone is allready unlocked now..
COM4 [VCP0] selected
module v1.57
Device: ZTE-125
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
sw version: -DE-P108A1V1.0.0B02 VDF-P108A1B07-De-DE03 g3dBV2.0 16 59 13 04.1
Check hardware Done
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20081126-123216.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20081126-123217.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20081126-123223.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_lock-area_20081126-123229.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 36 sec
The Following User Says Thank You to arabie For This Useful Post:
Old 11-26-2008, 09:23   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
It's a good example that users should visit support area from time to time and download latest updates due to we make improvements in software every day, add new models and improve operations for old models.
Old 12-07-2008, 03:56   #4 (permalink)
Member: 176714
Thanks Meter: 33
would you post pinout for this phone ,vodafone 125
Old 12-07-2008, 09:54   #5 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
here it is
Cable name: ZTE-225
keyboard top
1..........8
1: phone Tx (RJ-45 pin-3)
2: phone Rx (RJ-45 pin-2)
3: Gnd
Faisal_Computer
Old 12-07-2008, 11:34   #6 (permalink)
Member: 130995
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is information how to build your own cable: http://forum.gsmhosting.com/vbb/showthread.php?t=342807
infinity team pls help??? e71+ firmware. help??nfinity team pls. help?? vintel Infinity-Box 4 03-07-2010 11:29
Infinity team pls help vpriya Infinity-Box 3 10-17-2009 16:49
infinity team pls... help! tabuki Infinity-Box 2 12-23-2007 09:02
Infinity Team pls help me jhay_12 Infinity-Box 8 08-27-2007 10:32
infinity team pls help for c261 unlock user lock siang8788 Infinity-Box 4 01-13-2007 20:05
Page generated in 0.18267 seconds with 9 queries
