04-05-2009, 05:21 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | zte 225 dead after unlock COM7 [VCP0] selected module v1.65 Device: ZTE-225 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... sw version: VDF-P108A2B07-Hi-IN05 g3dBV2.0 04.12.00 18.26.11 08.02.00 10 53 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-static_20090405-094700.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-security_20090405-094701.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-complete_20090405-094708.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_lock-area_20090405-094721.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 51 sec Remove/Install battery now ! |
04-05-2009, 05:40 | #3 (permalink) |
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | yes i try to flash phone then i face this problem COM7 [VCP0] selected module v1.65 Device: ZTE-225 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-static_20090405-100824.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-security_20090405-100825.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-complete_20090405-100831.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware repair write error [00410000:0800]... error: write failed[00400000] Write Failed Finished, time used: 42 sec Remove/Install battery now ! |
04-05-2009, 06:00 | #6 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | select zte-225 fm. Then try to flash with different flash fiels. If not then pm me i will give u a crack software for flashing. Becasue in infinity i cannot use crack software. |
04-05-2009, 08:17 | #7 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
04-05-2009, 19:55 | #10 (permalink) | |
1. select model BSNL-200 2. flash phone again | |
04-08-2009, 18:23 | #13 (permalink) |
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | COM4 selected module v1.64 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20090408-225038.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20090408-225038.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20090408-225039.B1E.bin backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Write Done Finished, time used: 86 sec Remove/Install battery now ! phone not on i taierd |
ZTE a36G+ dead after UNlock with INFINITY BOX. MODEL KG370 | residentdenuevo | Infinity-Box | 20 | 08-25-2009 17:10 |
polar Team- zte a36G + dead after Unlock failed. :::ANSWERED::: | residentdenuevo | PolarBox 3 | 6 | 08-24-2009 18:46 |
ZTE A62 dead after unlock | ayhen42 | FuriousGold | 5 | 07-10-2009 06:53 |
