Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2009 Location: ua
Member: 1001119 Status: Offline Sonork: 100.1601226 Thanks Meter: 129 | zte 7350n flash problem like the log EMI : Init EMI from PRELOADER DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! if not flash pre file flash ok but phone not power on Include writing original backup files. Operation : Read Firmware [ v2.32 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1633 (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Palmer TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6833 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1633 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Palmer TYPE : MODERN [RAPHAEL] BROM : MEID : BC0A6E82367E773611E4D159CBB82F5C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : D74C9AA5CDB185F3789B61D649DC687D6F1DE70EE1AFE7341D 5B68D57832021D BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6833 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k6833v1_64.bin EMI : CNT : 000F EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : F4012241525632315811FF3985FC39DF EMMC: VEN : BIWIN : OEM : 34 : ID : 415256323158 EMMC: VEN : BIWIN : ARV21X EMMC: SNN : 4281959932 ( 0xFF3985FC) , MF : 3/2022 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1CD0000000 [ 115.25 GB ] CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : FAEB876DA063F0107C392E142CA16075 DA : USB : HIGH-SPEED Boot done! Info : Device support slots Info : Active slot : a Product Brand : ZTE Product Device : P633S07 Product Model : ZTE 7530N Product Name : CN_P633S07 Patch Level : RP1A.200720.011 Display ID : MyOS11.0.16_7530N_GEN Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-05-05 Build Time : 11.06.2021 Product Info : k6833v1_64 Product Board : Aries Product Manfct : ZTE Board Platform : mt6833 MT6833__ZTE__ZTE_7530N__11__MyOS11.0.16_7530N_GEN_ _RP1A.200720.011__k6833v1_64 Read : preloader.bin Read : ztecfg.img Read : vbmeta.img Read : vbmeta_system.img Read : vbmeta_vendor.img Read : persist.img ExtSparse : Compression ratio : 36% Read : md1rom.img Read : md1dsp.img Read : spmfw.img Read : pi_img.img Read : dpm.img Read : tinysys-scp.bin Read : sspm.img Read : mcupm.img Read : lk.bin Read : boot.img Read : dtbo.img Read : tz.img Read : proinfo.img Read : nvram.bin Read : logo.bin Read : super.img ExtSparse : Compression ratio : 16% Read : userdata.img FW Size : 5.01 GB Android Info saved : _Android_info.txt Scatter : MT6833_Android_scatter.txt Saved to : C:\Users\Administrator\Documents\MT6833__ZTE__ZTE_ 7530N__11__MyOS11.0.16_7530N_GEN__RP1A.200720.011_ _k6833v1_64\ Done! Elapsed: 00:09:13 Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_k6833v1_64.bin EMI : CNT : 000E EMI : [00] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8.00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 13014E47314A395139 : VEN : MICRON | DEV : G1J9Q9 : RAM : [ 6.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 150100335636434142 : VEN : SAMSUNG | DEV : 3V6CAB : RAM : [ 6.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 150100445636444142 : VEN : SAMSUNG | DEV : DV6DAB : RAM : [ 4.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 13014E47314331324C : VEN : MICRON | DEV : G1C12L : RAM : [ 8.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 450100444134313238 : VEN : SANDISK | DEV : DA4128 : RAM : [ 6.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 450100444134303634 : VEN : SANDISK | DEV : DA4064 : RAM : [ 4.00 GB ] EMI : [09] : eMMC : LP_DDR4X : ID : 150100445036444142 : VEN : SAMSUNG | DEV : DP6DAB : RAM : [ 4.00 GB ] EMI : [0A] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON | DEV : G1J9R8 : RAM : [ 4.00 GB ] EMI : [0B] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 8.00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] Operation : Write Flash [ v2.32 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :19 [FL] : Set : preloader_k6833v1_64.bin [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : md1img-verified.img [FL] : Set : md1dsp-verified.img [FL] : Set : spmfw-verified.img [FL] : Set : pi_img-verified.img [FL] : Set : dpm-verified.img [FL] : Set : scp-verified.img [FL] : Set : sspm-verified.img [FL] : Set : mcupm-verified.img [FL] : Set : lk-verified.img [FL] : Set : boot.img [FL] : Set : dtbo-verified.img [FL] : Set : tee-verified.img [FL] : Set : logo-verified.bin [FL] : Set : super.img [FL] : Set : userdata.img [FL] : Total size : 0x139799548 [ 4.90 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1633 (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Palmer TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6833 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1633 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Palmer TYPE : MODERN [RAPHAEL] BROM : MEID : BC0A6E82367E773611E4D159CBB82F5C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : D74C9AA5CDB185F3789B61D649DC687D6F1DE70EE1AFE7341D 5B68D57832021D BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6833 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_k6833v1_64.bin EMI : CNT : 000E EMI : [00] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8.00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 13014E47314A395139 : VEN : MICRON | DEV : G1J9Q9 : RAM : [ 6.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 150100335636434142 : VEN : SAMSUNG | DEV : 3V6CAB : RAM : [ 6.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 150100445636444142 : VEN : SAMSUNG | DEV : DV6DAB : RAM : [ 4.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 13014E47314331324C : VEN : MICRON | DEV : G1C12L : RAM : [ 8.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 450100444134313238 : VEN : SANDISK | DEV : DA4128 : RAM : [ 6.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 450100444134303634 : VEN : SANDISK | DEV : DA4064 : RAM : [ 4.00 GB ] EMI : [09] : eMMC : LP_DDR4X : ID : 150100445036444142 : VEN : SAMSUNG | DEV : DP6DAB : RAM : [ 4.00 GB ] EMI : [0A] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON | DEV : G1J9R8 : RAM : [ 4.00 GB ] EMI : [0B] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 8.00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! Operation : Write Flash [ v2.32 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Disabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :18 [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : md1img-verified.img [FL] : Set : md1dsp-verified.img [FL] : Set : spmfw-verified.img [FL] : Set : pi_img-verified.img [FL] : Set : dpm-verified.img [FL] : Set : scp-verified.img [FL] : Set : sspm-verified.img [FL] : Set : mcupm-verified.img [FL] : Set : lk-verified.img [FL] : Set : boot.img [FL] : Set : dtbo-verified.img [FL] : Set : tee-verified.img [FL] : Set : logo-verified.bin [FL] : Set : super.img [FL] : Set : userdata.img [FL] : Total size : 0x139738764 [ 4.90 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1633 (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Palmer TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6833 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1633 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Palmer TYPE : MODERN [RAPHAEL] BROM : MEID : BC0A6E82367E773611E4D159CBB82F5C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : D74C9AA5CDB185F3789B61D649DC687D6F1DE70EE1AFE7341D 5B68D57832021D BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6833 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k6833v1_64.bin EMI : CNT : 000F EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : F4012241525632315811FF3985FC39DF EMMC: VEN : BIWIN : OEM : 34 : ID : 415256323158 EMMC: VEN : BIWIN : ARV21X EMMC: SNN : 4281959932 ( 0xFF3985FC) , MF : 3/2022 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1CD0000000 [ 115.25 GB ] CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : FAEB876DA063F0107C392E142CA16075 DA : USB : HIGH-SPEED Boot done! [FL] : COMBO scatter! Update settings to eMMC [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : md1img-verified.img [FL] : Set : md1dsp-verified.img [FL] : Set : spmfw-verified.img [FL] : Set : pi_img-verified.img [FL] : Set : dpm-verified.img [FL] : Set : scp-verified.img [FL] : Set : sspm-verified.img [FL] : Set : mcupm-verified.img [FL] : Set : lk-verified.img [FL] : Set : boot.img [FL] : Set : dtbo-verified.img [FL] : Set : tee-verified.img [FL] : Set : logo-verified.bin [FL] : Set : super.img [FL] : Set : userdata.img SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000006A08000 Erase : 0x0000000008A88000 : 0x0000000009000000 Erase : 0x0000000016000000 : 0x000000001B700000 Erase : 0x0000000035A00000 : 0x0000000246600000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : VBMETA_A Write : VBMETA_SYSTEM_A Write : VBMETA_VENDOR_A Write : MD1IMG_A Write : MD1DSP_A Write : SPMFW_A Write : PI_IMG_A Write : DPM_A Write : SCP_A Write : SSPM_A Write : MCUPM_A Write : LK_A Write : BOOT_A Write : DTBO_A Write : TEE_A Write : LOGO Write : SUPER Write : USERDATA SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:04:14 Reconnect Power/Cable! Created by Infinity-Box (c) 2021 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Product Brand : ZTE Product Device : P633S07 Product Model : ZTE 7530N Product Name : CN_P633S07 Patch Level : RP1A.200720.011 Display ID : MyOS11.0.16_7530N_GEN Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-05-05 Build Time : 11.06.2021 Product Info : k6833v1_64 Product Board : Aries Product Manfct : ZTE Board Platform : mt6833 Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_k6833v1_64.bin EMI : CNT : 000E EMI : [00] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8.00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 13014E47314A395139 : VEN : MICRON | DEV : G1J9Q9 : RAM : [ 6.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 150100335636434142 : VEN : SAMSUNG | DEV : 3V6CAB : RAM : [ 6.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 150100445636444142 : VEN : SAMSUNG | DEV : DV6DAB : RAM : [ 4.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 13014E47314331324C : VEN : MICRON | DEV : G1C12L : RAM : [ 8.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 450100444134313238 : VEN : SANDISK | DEV : DA4128 : RAM : [ 6.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 450100444134303634 : VEN : SANDISK | DEV : DA4064 : RAM : [ 4.00 GB ] EMI : [09] : eMMC : LP_DDR4X : ID : 150100445036444142 : VEN : SAMSUNG | DEV : DP6DAB : RAM : [ 4.00 GB ] EMI : [0A] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON | DEV : G1J9R8 : RAM : [ 4.00 GB ] EMI : [0B] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 8.00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] Operation : Write Flash [ v2.32 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Disabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :34 [FL] : Set : preloader_k6833v1_64.bin [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : pi_img.img [FL] : Set : dpm.img [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : mcupm.img [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : logo.bin [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : pi_img.img [FL] : Set : dpm.img [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : mcupm.img [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : super.img [FL] : Set : userdata.img [FL] : Total size : 0x13F535DFC [ 4.99 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Palmer TYPE : MODERN [RAPHAEL] BROM : MEID : BC0A6E82367E773611E4D159CBB82F5C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : D74C9AA5CDB185F3789B61D649DC687D6F1DE70EE1AFE7341D 5B68D57832021D BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6833 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SETUP HW PARAMS FAILED! PROTO_VER is OLD? Error : Fail to init protocol! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Write Flash [ v2.32 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :34 [FL] : Set : preloader_k6833v1_64.bin [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : pi_img.img [FL] : Set : dpm.img [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : mcupm.img [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : logo.bin [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : pi_img.img [FL] : Set : dpm.img [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : mcupm.img [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : super.img [FL] : Set : userdata.img [FL] : Total size : 0x13F535DFC [ 4.99 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek DA USB VCOM (Android) (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Write Flash [ v2.32 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :34 [FL] : Set : preloader_k6833v1_64.bin [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : pi_img.img [FL] : Set : dpm.img [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : mcupm.img [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : logo.bin [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : pi_img.img [FL] : Set : dpm.img [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : mcupm.img [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : super.img [FL] : Set : userdata.img [FL] : Total size : 0x13F535DFC [ 4.99 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Palmer TYPE : MODERN [RAPHAEL] BROM : MEID : BC0A6E82367E773611E4D159CBB82F5C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : D74C9AA5CDB185F3789B61D649DC687D6F1DE70EE1AFE7341D 5B68D57832021D BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6833 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_k6833v1_64.bin EMI : CNT : 000E EMI : [00] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8.00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 13014E47314A395139 : VEN : MICRON | DEV : G1J9Q9 : RAM : [ 6.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 150100335636434142 : VEN : SAMSUNG | DEV : 3V6CAB : RAM : [ 6.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 150100445636444142 : VEN : SAMSUNG | DEV : DV6DAB : RAM : [ 4.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 13014E47314331324C : VEN : MICRON | DEV : G1C12L : RAM : [ 8.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 450100444134313238 : VEN : SANDISK | DEV : DA4128 : RAM : [ 6.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 450100444134303634 : VEN : SANDISK | DEV : DA4064 : RAM : [ 4.00 GB ] EMI : [09] : eMMC : LP_DDR4X : ID : 150100445036444142 : VEN : SAMSUNG | DEV : DP6DAB : RAM : [ 4.00 GB ] EMI : [0A] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON | DEV : G1J9R8 : RAM : [ 4.00 GB ] EMI : [0B] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 8.00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! Operation : Write Flash [ v2.32 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Disabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :33 [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : pi_img.img [FL] : Set : dpm.img [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : mcupm.img [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : logo.bin [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : pi_img.img [FL] : Set : dpm.img [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : mcupm.img [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : super.img [FL] : Set : userdata.img [FL] : Total size : 0x13F4D5018 [ 4.99 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Palmer TYPE : MODERN [RAPHAEL] BROM : MEID : BC0A6E82367E773611E4D159CBB82F5C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : D74C9AA5CDB185F3789B61D649DC687D6F1DE70EE1AFE7341D 5B68D57832021D BROM : SLA : Local Auth BROM : SLA : Starting Auth Error : Protocol Error : Fail to init Control! >>> Check USB driver, restart software Reconnect Power/Cable! Operation : Write Flash [ v2.32 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Disabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :33 [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : pi_img.img [FL] : Set : dpm.img [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : mcupm.img [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : logo.bin [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : pi_img.img [FL] : Set : dpm.img [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : mcupm.img [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : super.img [FL] : Set : userdata.img [FL] : Total size : 0x13F4D5018 [ 4.99 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Palmer TYPE : MODERN [RAPHAEL] BROM : MEID : BC0A6E82367E773611E4D159CBB82F5C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : D74C9AA5CDB185F3789B61D649DC687D6F1DE70EE1AFE7341D 5B68D57832021D BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6833 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k6833v1_64.bin EMI : CNT : 000F EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : F4012241525632315811FF3985FC39DF EMMC: VEN : BIWIN : OEM : 34 : ID : 415256323158 EMMC: VEN : BIWIN : ARV21X EMMC: SNN : 4281959932 ( 0xFF3985FC) , MF : 3/2022 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1CD0000000 [ 115.25 GB ] CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : FAEB876DA063F0107C392E142CA16075 DA : USB : HIGH-SPEED Boot done! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000006A08000 Erase : 0x0000000008A88000 : 0x0000000009000000 Erase : 0x0000000016000000 : 0x0000000000800000 Erase : 0x0000000019800000 : 0x0000000017F00000 Erase : 0x0000000035A00000 : 0x0000000246600000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : VBMETA_A Write : VBMETA_SYSTEM_A Write : VBMETA_VENDOR_A Write : VBMETA_B Write : VBMETA_SYSTEM_B Write : VBMETA_VENDOR_B Write : MD1IMG_A Write : MD1DSP_A Write : SPMFW_A Write : PI_IMG_A Write : DPM_A Write : SCP_A Write : SSPM_A Write : MCUPM_A Write : LK_A Write : BOOT_A Write : DTBO_A Write : TEE_A Write : LOGO Write : MD1IMG_B Write : MD1DSP_B Write : SPMFW_B Write : PI_IMG_B Write : DPM_B Write : SCP_B Write : SSPM_B Write : MCUPM_B Write : LK_B Write : BOOT_B Write : DTBO_B Write : TEE_B Write : SUPER Write : USERDATA SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:03:05 Reconnect Power/Cable! |
