09-28-2008, 23:26 | #1 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | ZTE-A139: we are looking for phone for tests If you have ZTE-A139 model on hands and ready to spend some time in testing, please, contact us. If you have this phone on hands and if you have Infinity-Box PinFinder please, make automatic pinout detection as MT6225 CPU and post pinout here. Thank you in advance ! |
10-02-2008, 10:40 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Phone connector has 8 pins only. I am sure you can find GND and Charge pins easily. If you can find RX and TX pins from rest 6 pins, please, read flash from this phone with ChineseMiracle software and send backup flash file to: [email protected] |
10-04-2008, 20:52 | #4 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: ๑۩۞۩&&
Member: 178790 Status: Offline Sonork: 100.1593063 Thanks Meter: 1,234 | Quote:
sending backup of ZTE A139..... and one message show by the box. | |
10-05-2008, 00:16 | #5 (permalink) |
Member: 178790 Status: Offline Sonork: 100.1593063 Thanks Meter: 1,234 | its the operations log.. unlock not work... not supported yet.. COM9 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:6103:0003 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.SE-VE-MOVISTAR-P103C2V1_0_6B05.BIN ver. sw2: SE-VE-MOVISTAR-P103C2V1.0.6B05, 00000000 ffs offset/size: 00A00000/00600000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00A00000 flash: 01227E22202200:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00C00000 Detected eeprom/ffs address is non-standard: 00C00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00C00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00400000 ffs chip: 00 eeprom/ffs area: 00000000:00C00000-00FFFFFF detecting ffs structure pass 1... .................. detect standard fat location pass #1... ................................................ detect extended fat location pass #1... .................................... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 01227E22202200:2AEA0000000000 Backup required data Done Patch required data... .................................... lock area found Patch required data Done Special operation... Special operation Done Write... flash: 01227E22202200:2AEA0000000000 flash: 01227E22202200:2AEA0000000000 Write: lock-area-1 Write Done Finalization... Finalization Done Finished, time used: 127 sec Remove/Install battery now ! |
10-05-2008, 18:43 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Thank you ! Please, try to keep phone with you for 1-2 days, we need some time to check flash backup. |
10-06-2008, 15:43 | #7 (permalink) |
Member: 178790 Status: Offline Sonork: 100.1593063 Thanks Meter: 1,234 | ok...man.. I bought the phone just to test the unlock... PD:: The Imei Change work perfect. ;D we..are .waiting for your Answer ! XD |
10-06-2008, 19:24 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to use this software: www.infinity-box.biz/download/public/MModule.rar Try to use different unlock methods (read unlock codes etc.) Waiting for your results. |
10-06-2008, 21:08 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | HEllo, Please, try to unlock phone by all possible methods. Send operation.log file to check: [email protected] What code phone ask to enter ? |
10-08-2008, 19:40 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is it: Here is link to new software: http://rapidshare.com/files/152123034/MModule.rar.html Waiting for your results. |
!!!!!! We are looking for the next phones !!!!!! | GSMtricks | Multi-Box | 132 | 09-29-2009 21:10 |
We are looking for Full Flash Files read from Chinese Phones with Infineon CPU | nonu_don | ET-BoX | 8 | 10-16-2008 12:09 |
We are looking for these phones !! | SiRoYa | UST Pro II | 38 | 02-23-2007 00:17 |
We are looking for beta-testers who has different Chinese phones on hands for tests | InfinitySupport | Infinity-Box | 14 | 11-21-2006 16:33 |
We Are Looking Cell Phones Gsm 850 Mhz | mustai | Wanted Products | 4 | 03-06-2006 23:00 |
