05-21-2014, 09:29 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity-Box Chinese Miracle-2 (Test Version) SPD/Spreadtrum v0.05 released .SPD6610/SPD6620 CPU supported - Read flash - Write flash - Safe format - Read User Code - Repair IMEI .SPD6530 support improved - Dual-Flash IC initial support: Read/Write/Format/UserCode - User Code read operation improved - Repair IMEI procedure improved - Reset Screen Lock improved: TouchPhones .SPD6531 support improved - Dual-Flash IC initial support: Read/Write/Format/UserCode - User Code read operation improved - Repair IMEI procedure improved - Reset Screen Lock improved: TouchPhones .SPD653x Samsung phones support - Read Flash - Write flash (Warning, use only for restore backup or repair dead one!!!) - Format/Reset - Read UserCode - Repair IMEI (1/2 slot) Supported models: GT-E1200i GT-E1205i GT-E1270 GT-E1272 GT-E1282T GT-E2202 .Common operations - Repair IMEI enabled from normal mode - Support several original brands based on SPD6531/SPD6610/SPD6530: Fly, Alcatel etc. - For Samsung phones required Select "Samsung" in CPU list. - User Code read operation improved - File naming procedure updated to avoid wrong file names after flash read - CompileInfo extraction revised, support for 66xx platform - Initial File Check revised - "Smart Format" revised for 6530/6531 platforms. Main changes on support 16/32mb FlashChip - Flash Read revised , read error correction mode improved - Support for different drivers versions and revisions (Boot/Normal/Service connection) Please, post your test-reports here: http://forum.gsmhosting.com/vbb/f296...dtrum-1808794/ How to activate this software: http://forum.gsmhosting.com/vbb/f296...dtrum-1808794/ |
The Following 4 Users Say Thank You to YellowBoss For This Useful Post: |
05-21-2014, 14:36 | #8 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | It support all FlashIC sizes, not matter. And With 4/8 it even more better, because less garbage things inside Please, make FlashRead and send me dump. We will fix that in near time. |
The Following User Says Thank You to Dzirt For This Useful Post: |
05-23-2014, 18:53 | #12 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Friends, Please, post your test report in main thread regarding CM-2 SPD software: http://forum.gsmhosting.com/vbb/f296...dtrum-1808794/ This helps us to see results in one place and to make updates fast. Thank you ! P.S. Several messages from current thread will be moved now to http://forum.gsmhosting.com/vbb/f296...dtrum-1808794/ |
