zte a211 unlock done COM3 [VCP0] selected module v2.48 Action: unlock unlock method: smart fast Model: ZTE-A211 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:31FC:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: PE-PT-TMN-P109A2V1.0.2B05 Version: 07AZTENJ23_07A_PMJ 44 byte(s) read imei: 35547302011433 connection Ok 157 byte(s) read reading data... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! thanks to infinity team |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
can you please tell me wich cable did you use. Thanks and regards |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: http://www.infinity-box.com/download...shell_v126.jpg Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
ZTE A211 pinout PANFINDER RX1 TX2 |
