12-17-2008, 08:35 | #20 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 200145 Status: Offline Sonork: 100.1596786 Thanks Meter: 677 | i faced the same problm for this model..zte a61 COM9 [VCP0] selected Device: ZTE-A61 Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-sta_20081217-124627.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-sec_20081217-124629.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-complete_20081217-124637.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Write Done Finished, Remove/Install battery now ! Time used: 32 sec later i flashed the phone wth the flash file ,wat u recommended here ZTE-A35_Main_LP_TELMA-P108A5B01-Fr-MG01_g3dBV2.0_Jun-19-2007!!!! then i unlocked.. still im facing the same problm.. help me out. thnks in advance |
12-17-2008, 09:25 | #21 (permalink) |
Member: 200145 Status: Offline Sonork: 100.1596786 Thanks Meter: 677 | hai infinity support i solved the problm in ... (MAY BE THE SAME THING WILL DO SUCCESS IN INFINITY TOO..BY CHOOSING ZTE 225 FM IN INFINITY TOO !!!)BUT I DIDNT TRIED.. ANYONE TRIED IN THIS WAY,KINDLY REPRT..BECOZ,IT SAVES TIME(BY MAKING BACK UP..THEN FLASH..THEN UNLOCK) @ INFINITY SUPPORT.. KNDLY CONSIDER THIS BUG BY PROVIDING DIRECT UNLOCK FOR THIS MODEL THANKS IN ADVANCE.. Last edited by InfinitySupport; 12-17-2008 at 18:51. Reason: offtopic text deleted |
12-17-2008, 18:54 | #22 (permalink) | |
You must check Infinity-Box support area at least two times per week due to Infinity-Box release new updates and support new models and features very fast. Read this: http://forum.gsmhosting.com/vbb/showthread.php?t=636814 hope you will be able to say truth here about The Great Infinity-Box next time. p.s. I strongly suggest you to avoid advertizing of other products in current forum, here is Infinity-Box support forum ! | |
12-18-2008, 11:33 | #23 (permalink) |
Insane Poster Join Date: Oct 2007 Location: tamilnadu,india Age: 38
Member: 618006 Status: Offline Thanks Meter: 62 | ZTE A61 unlock 100% working..... ZTE A61 kalifoniya operater celtel.....unlock log.. working 100%.... COM3 [VCP0] selected module v1.58 Device: ZTE-A61 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: TEL-P108A11V1.0.0B03 CELTEL-P108A11B01-EnFr-01 g3dBV2.0 04.12.00 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-static_20081218-022847.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-security_20081218-022848.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-complete_20081218-022854.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_lock-area_20081218-022901.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 51 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to sunamuni_1985 For This Useful Post: |
12-18-2008, 12:45 | #25 (permalink) | |
Member: 200145 Status: Offline Sonork: 100.1596786 Thanks Meter: 677 | Quote:
hai,im very very sorry if i hurt u by any means..im not in intensn to advertise any product..i always loves each and every box i had..also im having more respect and value with the infinity team.. s,u r right..2day i downloaded pan v1.58..i directly unlocked blocked zte 225. good luck.. keep going | |
The Following User Says Thank You to .::koolfriend4u::. For This Useful Post: |
12-18-2008, 12:50 | #26 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | @ .::koolfriend4u::. you apologize good , and one personal suggestion that NEVER EVER talk other boxes to any other boxes support forum i hope you understand Br Faisal_Computer |
The Following User Says Thank You to Faisal_Computer For This Useful Post: |
12-18-2008, 19:10 | #27 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. | |
12-22-2008, 09:29 | #28 (permalink) |
Junior Member Join Date: Jul 2008
Member: 825002 Status: Offline Thanks Meter: 0 | unable to unlock zte A61 I try to unlock my zte A61. The report text is good, but when i turn on the phone whit another sim, i see this message on screen: "sim bolcked" My phone is zte A61 Congo RDC Celte operator I need your help to solve my problem Thank. |
12-22-2008, 09:44 | #29 (permalink) | |
Did you tried to use latest Pana01 module version ? Post operation log here. | |
ZTE A61 unlock problem | Dr.Nabil | FuriousGold | 17 | 08-09-2010 09:46 |
ZTE A61 unlock problem | Dr.Nabil | FuriousGold | 5 | 12-19-2009 15:20 |
ZTE A61 Unlock Successfully | kabo tel | Infinity-Box | 3 | 09-28-2009 17:25 |
ZTE-A61 Unlocking | xtream 08 | Infinity-Box | 7 | 06-25-2008 16:46 |
Zte A61 Unlock Successfully | denard | SAGEM JTAG UNLOCKER | 3 | 04-12-2008 19:34 |
