03-20-2017, 14:01 | #1 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Algeria
Member: 2105719 Status: Offline Thanks Meter: 20 | ZTE Blade A460 FRP Done Operation : Identify [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 02769739 ID_BLOCK_I : 009600E1 ID_BLOCK_L : B5E02EA94CB086B9E22B322271B9A217 ID_BLOCK_L : 66D7CC937E2BDDD87569FF36D5616BAB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : ZTE ProdName : P809A20 ProdModel : ZTE Blade A460 Device : P809A20 AndroidVer: 5.1.1 Manufact. : ZTE QLMxCPU : MSM8909 Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Reset Settings [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 02769739 ID_BLOCK_I : 009600E1 ID_BLOCK_L : B5E02EA94CB086B9E22B322271B9A217 ID_BLOCK_L : 66D7CC937E2BDDD87569FF36D5616BAB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
03-31-2017, 10:22 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | If device can't be forced to EDL by buttons - try fastboot mode, if it not work - then edl cable. 5 minutes to make it from simple one need. |
04-09-2018, 15:20 | #9 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1865419 Status: Offline Thanks Meter: 5 | reset frp zte a460 easy way is via adb+fastboot power off phone press and hold volume up +power now in recovery mode select reboot to bootloader not in cmd type fastboot erase config. then fastboot reboot and done. |
The Following 2 Users Say Thank You to carlitossatan For This Useful Post: |
