04-21-2021, 19:28 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | ZTE Blade A5 2020 supported ? Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.10 Load IDBase v8331 Ok! Failed to prepare enivorment! Operation : Identify [ v2.10 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863A_eMMC_3GB_0S Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Identify [ v2.10 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! >>> ERROR : Protocol HandShake failed! >>> Error : Fail to init protocol! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.10 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_3GB_RS Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Identify [ v2.10 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! >>> ERROR : Protocol HandShake failed! >>> Error : Fail to init protocol! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.10 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_3GB_RS Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! |
04-21-2021, 19:52 | #2 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 449 | Now have sucessfull read phone selecting ZTE BLADE A5 A7 2019 ,now my question is , could i unlock this phone ? Operation : Identify [ v2.10 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : ZTE : ZTE_BLADE_A5_A7_[2019] Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : ZTE Blade A5 2020B01-PT_MR01a Ver. Incmt : 20200526.130959 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-05-05 Build Time : 26.05.2020 Product Model : ZTE Blade A5 2020 Product Brand : ZTE Product Name : GEN_EU_EEA_P963F50 Product Device : P963F50 Product Manfct : ZTE Product Info : P963F50 Product Name : s9863a1h10_Natv Product Device : s9863a1h10 Product Board : smooth Board Platform : sp9863a Platform Version: MOCORTM_18B_W19.10.2_ZLA_P23_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W19.10.2_ZLA_P23 HW Version: sc9863A_modem MODEM TAG : MOCORTM_18B_W19.10.2_ZLA_P23_Debug_FM_BASE_18B_W19 .10.2_ZLA_P23_sc9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:04:22 |
The Following User Says Thank You to ct3im For This Useful Post: |
04-21-2021, 21:27 | #3 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 449 | And the strange is , if i try read phone selecting the correct model ZTE BLADE A5 2020 give error Operation : Identify [ v2.10 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : ZTE : ZTE_Blade_A5_2020 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... >>> ERROR : FLASH FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! |
04-21-2021, 23:47 | #6 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 449 | Full firmware backup. Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.11 Load IDBase v8331 Ok! Operation : Identify [ v2.11 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : ZTE : ZTE_BLADE_A5_A7_[2019] Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : ZTE Blade A5 2020B01-PT_MR01a Ver. Incmt : 20200526.130959 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-05-05 Build Time : 26.05.2020 Product Model : ZTE Blade A5 2020 Product Brand : ZTE Product Name : GEN_EU_EEA_P963F50 Product Device : P963F50 Product Manfct : ZTE Product Info : P963F50 Product Name : s9863a1h10_Natv Product Device : s9863a1h10 Product Board : smooth Board Platform : sp9863a NVMng : SecurityInfo IMEI[1] : 868xxxxxxxxxxxx IMEI[2] : 868xxxxxxxxxxxx IMEI[3] : 867xxxxxxxxxxxx SEC : SLS:2, SKS:0, SKV:4 Platform Version: MOCORTM_18B_W19.10.2_ZLA_P23_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W19.10.2_ZLA_P23 HW Version: sc9863A_modem MODEM TAG : MOCORTM_18B_W19.10.2_ZLA_P23_Debug_FM_BASE_18B_W19 .10.2_ZLA_P23_sc9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:14:54 Operation : Read FW [ v2.11 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : ZTE : ZTE_BLADE_A5_A7_[2019] Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : ZTE Blade A5 2020B01-PT_MR01a Ver. Incmt : 20200526.130959 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-05-05 Build Time : 26.05.2020 Product Model : ZTE Blade A5 2020 Product Brand : ZTE Product Name : GEN_EU_EEA_P963F50 Product Device : P963F50 Product Manfct : ZTE Product Info : P963F50 Product Name : s9863a1h10_Natv Product Device : s9863a1h10 Product Board : smooth Board Platform : sp9863a AndroidVer : 9 VlnrLevel : 0x02 SP9863A__ZTE__ZTE_Blade_A5_2020__9__ZTE_Blade_A5_2 020B01-PT_MR01a__PPR1.180610.011__P963F50 Read : u-boot.bin Read : sml.bin Read : tos.bin Read : vbmeta.img Read : dtb.img Read : dtbo.img Read : ldsp_l.bin Read : gdsp_l.bin Read : modem_l.bin Read : nvitem_l.bin Read : deltanv_l.bin Read : modem_wcn.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : pm_sys.bin Read : boot.img Read : recovery.img Make : persist.img Read : boot_logo.bmp Read : fastboot_logo.bmp Read : system.img Read : vendor.img Read : otp_product.img Make : userdata.img Make : cache.img Read : prodnv.img ExtSparse : Compression ratio : 9% Read : phase.cfg Read : ztecfg.bin Read : ztepersist.bin ExtSparse : Compression ratio : 0% Read : u-boot-spl.bin Waiting for device ... ADB : Device found! ADB : Connected! ADB : Prepare Ok! Just some noise around. Wait ... Mankind should survive Found vodka! Firmware size : 0x109CAADEC ( 4,15 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:55:56 |
04-22-2021, 08:13 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | phones with old security is free (zero credits) phones with new security is 5 credits price - https://www.infinity-box.com/price/ Try to make unlock and software will tell you info |
