Old 11-16-2013, 10:43   #1 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
ZTE G R221 not unlocked via Infinity
I have ZTE G R221 - can not read codes, can not unlock with Standard method.
What can i do to unlock this phone?
btw: Can i edit flash file to get other language?
Old 11-17-2013, 14:53   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Post here phone IMEI
will post you Unlock Code
Old 11-17-2013, 17:23   #3 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
Allready unlocked via SIGMA's calculator but i wonder why can not unlock it via cabel and Infinity soft.
Old 11-20-2013, 12:55   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Please, in future posh here operation log text. It's very hard to understand what is the problem if you say just "not work".
In most cases problem with unlock is a problem with cable and wrong model selection, so we must see operation log text.
Old 11-20-2013, 22:37   #5 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
N.P.
==== C:\InfinityBox\MModule\MModule.exe [2013-11-16 10:20:38] ====
FREE DC-Unlocker account for Infinity-Box users:
http://forum.gsmhosting.com/vbb/f296/dc-unlocker-software-activation-infinity-box-users-free-unlock-available-1484571/
http://www.infinity-box.com
Loading data, wait...
[Infinity Box] MModule v4.40
smart-card: connected (Gemalto e-gate Smart Card 0)
S/N: 0XXX:0XXX:00
Wait...
trying to select model: /G-R221
Device: _Autodetect MT6205-6239 NOR
Initialization done
==== [2013-11-16 10:21:36] ====
COM2 [VCP0] selected
module  v4.40
Checking data, wait...
Operation: SP-unlock
unlock method: read codes
interface: META_DLL_v6.1108.00
Connect...
Connecting...
done
Release Power button now !
BaseBand chip version: MT6223, E08
ECO version:
DSP firmware version:  2000.00.00
DSP patch version: 1.0
S/W version: TMO_UK_P109A17V1.0.1B09
H/W board version: ZTENJ23D_09A_HW
Melody version Melody V0.0
Version: TMO_UK_P109A17V1.0.1B09
detecting structure imei...
 done
86 byte(s) read
imei #1: 868533006754809F7810
detecting structure simlock...
error: detection failed (17 tries)
error: detection failed (2 tries)
Shutdown...
done
Finished, time used: 1 min 28 sec
Remove/Install battery now !
==== [2013-11-16 10:25:13] ====
module  v4.40
Connect...
Connecting...
done
ECO version:
 done
86 byte(s) read
Shutdown...
done
Finished, time used: 1 min 25 sec
==== C:\InfinityBox\MModule\MModule.exe [2013-11-16 10:29:47] ====
[Infinity Box] MModule v4.46
S/N: 0XXX:0XXX:00
Wait...
Initialization done
==== [2013-11-16 10:30:20] ====
module  v4.46
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A08]...
CPU: MT6223
high speed boot On
chip: 0011:7CC0:000C
status: FF
boot packet size: 0400
Boot Done
====>  Initialize ...
flash: 208848FFFFFFFF:20884800000000
flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb
otp offset: 007F0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
====>  Set baud ...
460800
Set baud Done
====>  Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00800000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (07)
TCL-ID is absent
rom info detection finished
rom info ver: 07
sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P109A17V1_0_1B09.BIN
project-id: TMO_UK_P109A17V1.0.1B09, 00000000
code offset: 00000000
ffs offset/size [02]: 00600000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00600000
standard ffs/eeprom offset confirmed: 00600000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00600000-007FFFFF
firmware area: 00000000-005FFFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 1...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect ext location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P109A17V1_0_1B09__ffs...
file saved: C:\InfinityBox\MModule\ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P109A17V1_0_1B09__ffs_20131116-103333.B0E.bin
Backup required data Done
====>  Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write: ffs
Write Done
====>  Finalization ...
Finalization Done
Finished, time used: 3 min 48 sec
==== [2013-11-16 10:37:03] ====
module  v4.46
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====>  Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 07
TCL-ID is absent
ffs/eeprom chip: 00
reading: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P109A17V1_0_1B09__fullflash...
file saved: C:\Users\Robert\Desktop\ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P109A17V1_0_1B09__fullflash_20131116-104249.B0M.bin
Finished, time used: 8 min 51 sec
I have that flash.
The Following User Says Thank You to roberts For This Useful Post:
Old 11-22-2013, 00:18   #6 (permalink)
Member: 130995
Hello,
You have selected "Device: _Autodetect MT6205-6239 NOR" model instead of exact model selection.
Please, next time check model selection in software module, not only in Shell.
Old 12-04-2013, 08:03   #7 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 471
868533006754809
unlock code please check : 882156800440
thanks to infinity team
Old 12-04-2013, 08:13   #8 (permalink)
Member: 1435528
Sonork: 100.1603713
Thanks Meter: 217
Originally Posted by InfinitySupport View Post
Hello,
Dear Sir,
can you add spd chip and mstar chip and RDA ect in infinity box becouse maney monthe going you can not give most powearfull update on this box? can you tell me about this box futcher? its shoped? R onley CDMa phone update??
Page generated in 0.20444 seconds with 8 queries
