10-31-2010, 05:52 | #1 (permalink) |
No Life Poster Join Date: Aug 2009 Location: faisalabad PAKISTAN
Member: 1092450 Status: Offline Thanks Meter: 196 | 6300 dead plz help me chack log module v3.23 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:AA03:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20101031-094440.B0E.bin flash: 98000300000001:FFFFFF00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:FFFFFF00000000 Finalization Done Finished, time used: 4 min 24 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
10-31-2010, 13:04 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! software version can not be detected. best way is to disassemble phone and read short firmware version form phone PCB. use it for finding correct flash file |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
