08-08-2009, 08:42 | #1 (permalink) |
No Life Poster Join Date: Aug 2005
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | ZTE-G X760 unlock with infinity... I can see that the pin out ins on board, can i use pin finder with the mobile? Thank you in advance for your help. |
08-08-2009, 09:43 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Android developers
Member: 904753 Status: Offline Sonork: 100.1583681 Thanks Meter: 2,677 | Brother Use this TX RX METHOD... TODAY I UNLOCK COM9 [Serial2] selected Module v2.68 Action: Unlock Method of releasing: Intelligent Model: ZTE-X761 Checking Data. Wait ... The phone should be off! Press and hold the Connect button! 19200 autodetect Initializing [6225:8 A03: 8A00] ... CPU: MT6225 chip: 0001:7 C03: 000E status: FF Connecting at 19,200, wait ... Release the button to Connect! Phone Found. Wait ... Hardware: MT6225, E03 Date: 2006.06.14 Version: 1.0 Version: X760_Z1_P_B07A108 Version: ZTEMT25_07A_HW_E 44 byte (s) read IMEI: 35235302946618 Connected 157 byte (s) read Reading data ... reading data # 2 ... Building New Data ... Writing data ... 145 byte (s) read Reading data ... Building New Data ... Writing data ... Verifying ... Checking Made Finalized. Time Spent: 14 sec Remove / Replace the battery! Br. Waqar |
The Following 11 Users Say Thank You to ..::Waqar::.. For This Useful Post: |
08-08-2009, 17:20 | #3 (permalink) |
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | phone has warranty seal!!!! pin finder not working if not i will need to try by code!!! |
The Following User Says Thank You to ZIYAAD STRYKER For This Useful Post: |
08-11-2009, 11:32 | #8 (permalink) |
Freak Poster Join Date: Mar 2004 Location: at home
Member: 56735 Status: Offline Thanks Meter: 35 | here is pinout same than sfr 341 ( in support ) tested with zte g x760 configuration: pinout_308 Cable name: SFR-341 keyboard top connector 2x5 L10C 1 2 3 4 5 6 7 8 9 10 4: Box Tx/Phone Rx (RJ45 pin-2) 5: Box Rx/Phone Tx (RJ45 pin-3) 6: Gnd br |
The Following User Says Thank You to rachelyna For This Useful Post: |
08-13-2009, 06:43 | #10 (permalink) |
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | tried phone code reset not ok... unlock ok... COM22 [VCP0] selected module v2.83 Action: user code unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:8B03:000D status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: X760_Z15FR_FS_B07A101 Version: ZTEMT25_07A_HW_C 44 byte(s) read imei: 35235302158753 connection Ok 157 byte(s) read reading data... building new data... writing data... user code set to: 0000 Finished, time used: 14 sec Remove/Install battery now ! |
08-13-2009, 06:44 | #11 (permalink) |
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | COM22 [VCP0] selected module v2.83 Action: unlock unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:8B03:000D status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: X760_Z15FR_FS_B07A101 Version: ZTEMT25_07A_HW_C 44 byte(s) read imei: 35235302158753 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 16 sec i will upload firmware to rapidshare... quicker for me.. |
04-02-2010, 15:43 | #13 (permalink) |
Freak Poster Join Date: Mar 2006 Location: UK Age: 46
Member: 247226 Status: Offline Sonork: 100.1614366 Thanks Meter: 11 | hi there i'm getting problem in unlocking zte g x760. Always when i connect ph it comes on nothing much. COM1 selected module v3.30 Action: "sp-unlock" unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 44 sec Remove/Install battery now ! need urgent solution pzzz |
04-03-2010, 19:08 | #14 (permalink) | |
it's for sure cable/pinout problem. Please, double check your cable/pinout. Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum | |
07-13-2010, 20:16 | #15 (permalink) | |
No Life Poster Join Date: May 2007 Age: 42
Member: 501674 Status: Offline Sonork: THEIF OF HEART Thanks Meter: 883 | Quote:
slect zte x761 then press unlock button .... | |
Zte A66 possible unlock with infinity ? | abote didier | Infinity-Box | 21 | 06-19-2011 09:31 |
zte-g x760 unlock code pls | islambey | Phone Unlocking Codes & Maps | 1 | 01-22-2010 16:55 |
ZTE-G X760 unlock problem | Afzal Chiri | FuriousGold | 13 | 01-04-2010 19:43 |
ZTE-G X760 unlock? | foony | FuriousGold | 3 | 09-06-2009 07:34 |
zte a61 cant unlock with infinity | obioha | Infinity-Box | 1 | 05-16-2008 12:41 |
