06-20-2019, 21:09 | #1 (permalink) |
Freak Poster Join Date: May 2011 Location: algeria
Member: 1582098 Status: Offline Thanks Meter: 17 | ZTE MF710M unable to read / backup / unlock ( MT6280A ) i'm trying to boot and read info from CM2 Latest version MTK module 2.06 i tried different bases half of them are half booting when selecting option port : Brom only also how can i enable the menu CPU : Mediatek Feature Phone ( MT62xx/ MT25xx ) it is greyed out and i cant enable it. thanks for help , here is the logs : Code: Card found : *******, v0138 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v123080 Ok! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT0000 , SBID : 0x0000 , HWVR : 0x0000 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT0000 , SBID : 0x0000 , HWVR : 0x0000 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1820 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT0000 , SBID : 0x0000 , HWVR : 0x0000 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1836 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT0000 , SBID : 0x0000 , HWVR : 0x0000 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1836 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT0000 , SBID : 0x0000 , HWVR : 0x0000 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : MT6570_FACTORY | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM114) MODE : BOOTROM PORT : 114 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
06-23-2019, 18:22 | #5 (permalink) |
Member: 1582098 Status: Offline Thanks Meter: 17 | already tried with that version always gives the same error with different operations : Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 114 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6280 BB_CPU_HW : CA02 BB_CPU_SW : 0101 BB_CPU_SB : 8F00 BB_CPU_NM : [MediaTek] MTxxx BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 114 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6280 BB_CPU_HW : CA02 BB_CPU_SW : 0101 BB_CPU_SB : 8F00 BB_CPU_NM : [MediaTek] MTxxx BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
