Old 12-12-2016, 10:58   #1 (permalink)
Member: 1824929
Thanks Meter: 99
Qmobile Z14 Dead After Flash
Also write on bacup but phone dead
The Following User Says Thank You to sanyomobile For This Useful Post:
Old 12-12-2016, 11:47   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
After few years and thousand posts still have no idea about logs?
Bad luck then.
The Following User Says Thank You to JayDi For This Useful Post:
Old 12-12-2016, 11:54   #3 (permalink)
Member: 1824929
Thanks Meter: 99
======= Flash
Wait for phone...
Phone found! [ 34 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : PRELOADER
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM41X
[eMMC] : FLASH_CID : 150100525831344D4207B911DA078351
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0x1C66FE6FD9380CB52C9E54841ACEC644
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : HIGH-SPEED
Boot Ok!
ScatCFG : BaseBand : MT6755 , Project : gionee6755_66_m , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
M67BL : Check eMMC compatibility
M67BL : eMMC supported by BootLoader!
Checking and verifying PMT info
M67BL : Flash Erase
Total blocks to Erase : 5
Erase : 0x0000000000008000-0x0000000001A80000
Erase : 0x0000000001BC8000-0x0000000004000000
Erase : 0x0000000007000000-0x0000000000040000
Erase : 0x0000000007800000-0x0000000002C00000
Erase : 0x000000000A900000-0x000000073C2FBE00
Flash Erase Done, time used : 00:00:04
Processing : Writing all Flash Files
Flash Partition : PRELOADER
Flash PLC
Image Flash Ok
Flash Partition : RECOVERY
Image Flash Ok
Flash Partition : MD1IMG
Image Flash Ok
Flash Partition : MD1DSP
Image Flash Ok
Flash Partition : MD1ARM7
Image Flash Ok
Flash Partition : MD3IMG
Image Flash Ok
Flash Partition : LK
Image Flash Ok
Flash Partition : LK2
Image Flash Ok
Flash Partition : BOOT
Image Flash Ok
Flash Partition : LOGO
Image Flash Ok
Flash Partition : TEE1
Image Flash Ok
Flash Partition : TEE2
Image Flash Ok
Flash Partition : SECRO
Image Flash Ok
Flash Partition : SYSTEM
Image Flash Ok
Flash Partition : CACHE
Image Flash Ok
Flash Partition : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:02:43
Done!
Elapsed: 00:03:07
Reconnect Power/Cable!
Old 12-12-2016, 12:04   #4 (permalink)
JayDi's Avatar
Member: 462970
Is that FW factory one?
Old 12-12-2016, 12:06   #5 (permalink)
Member: 1824929
Thanks Meter: 99
yes i read this file from my Z14 and format after format phonw hang on logo....
and when i Flash readed File phone is Dead
Any solution
Old 01-01-2017, 18:50   #6 (permalink)
Member: 1253911
Thanks Meter: 16
You need signed firmware. Read firmware will not work at all...
Page generated in 0.16336 seconds with 8 queries
